Results 1 to 1 of 1
12-23-2010, 01:20 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
February 2011 New Hot Rod Products - Test And Tune
FAST and Racing Head Service teamed up to improve GM's LS3 engine, and the LSXR 102mm polymer intake manifold is the result.Graphite Lube In A Spray Can
Superior Graphite
800/366-3907
SlipPlate.com
Lubricating moving parts under the hood or on the chassis of your hot rod usually results in dirt and grime being attracted to the parts by the grease or oil you use. That's the case with most lubricants that are applied wet and stay wet. Slip Plate is a dry-film lubricant that contains a healthy amount of graphite, which is hydrophobic. That means it resists moisture and will keep on lubricating whatever metal parts you apply it to-even if you drive through rain, snow, or mud. Since the aerosol dries on contact, it also won't attract dirt. Slip Plate works great on metal, wood, and most polymer surfaces and will reduce friction and extend the service life of most parts.
Price: $8.47 for a 16-ounce can
Photo Gallery: February 2011 New Hot Rod Products - FAST LSXR 102mm Intake Manifold - Hot Rod Magazine
February 2011 New Hot Rod Products - Test And Tune | Digg It | Add to del.icio.us
More...
January 2011 New Hot Rod Products - Test And Tune
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 11-29-2010, 04:10 PM
