Thread: About Exhaust...or lack there of
12-19-2010, 08:20 PM #1Impounded
- Apr 2010
- IN
ok so me and a few of my friends are having a little argument..and i figure you guys know best.
they say if you take the exhaust off (example cut it mid y-pipe or just dump it after the stock cats) that it will mess up your engine unless you get a tune
i sided with that it doesnt because some people dont even run a tune after exhaust mods...
am i wrong?
12-19-2010, 08:41 PM #2Slow'er'Ass
- Thornton, CO
Not wrong.
And certainly isn't 'messing up the engine.'
Probably not making anymore power that way, but not breaking/hurting anything.
12-19-2010, 08:51 PM #3Impounded
- Apr 2010
- IN
thats what i said
i told them that the only reason for a tune is to maximize the gains of the exhaust
which...frost offers a damn good price nonetheless...
12-20-2010, 12:19 PM #4Junior Member
- Oct 2010
- Milwaukee, WI
white- 1998 Trans Am
if you loose anything it will be a little low end torque by not having a lot of back pressure
12-20-2010, 12:28 PM #5Grand Imperial Wizard
- Retired Outlaw Sum Bitch
DaveyG is right on the money. Back pressure = Torque.
12-20-2010, 05:18 PM #6Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
These guys are correct.
I had some personal experience with my old Pontiac 400.
It always seemed to have header leaks at the flange (until I finally solved it). When it did leak you could feel a noticeable difference in torque output from the engine.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
12-20-2010, 05:22 PM #7Impounded
- Apr 2010
- IN
So how do Kooks 1 7/8 LTs 3" ORY and SLP LMII do in terms of torque?
I mean i figure that a dyno would be needed to exacts...but shouldnt it go up?
12-20-2010, 06:11 PM #8
yes you total torque gains will be up in the higher rpms, regardless of losing a little bit of low end off the hit in the power band you will pick up hp and torque in the power band. I have seen this first hand from being stock to full exhaust on the same dyno and picked up more torque a little later in the power band. so the power curve isn't as strong off the hit but it does gain torque.
12-21-2010, 07:37 AM #9
That exact set-up is the only power mod I have on my car other than a lid. I'm a M6.
I DYNO'd 330rwhp/342rwtq through a 9" rear end, which is the least efficient rear end there is...so I know I left some on the table.
Those numbers were from a Mustang Dyno too. A DYNOJET would have read higher.
I didn't get a baseline run in with the car stock, but I would assume I gained close to 35/40 from other numbers I've seen on stock cars.
The important thing is that you have a car that is running properly. Don't get caught up in the numbers.
05 GTO Misfire, Hesitation, Lack Of Power
By MM Alexander in forum General HelpReplies: 4Last Post: 01-24-2014, 06:22 AM -
Can Windows 8 give developers what iOS and Android lack?
By Ed Blown Vert in forum Computers / GamingReplies: 0Last Post: 11-08-2012, 06:50 AM -
Help: Z28 lack of power during acceleration
By White Knight in forum General HelpReplies: 5Last Post: 02-25-2012, 01:49 PM -
Lack of Privileges
By nevadabob in forum Request and FeedbackReplies: 13Last Post: 02-20-2006, 08:23 AM -
Intermittent lack of power need help
By 98Roadster6speed in forum Computer & TuningReplies: 0Last Post: 09-21-2005, 04:44 AM
