Results 1 to 20 of 20
    Dec 2010
    New York
    2000 Camaro z28
    Help!-My Trunk latch is recycling.
    I have a 2000 Z28 and last night the alarm went off. I reset it and this morning when I got up the trunk was open and the latch was recycling. I would shut it and in a few seconds is would open. I can't reset the alarm now. We did have a rainy windy night last night. Any suggestions?
    Retired Outlaw Sum Bitch
    Pull the fuse. Take your test light and check the switch.
    Dec 2010
    New York
    2000 Camaro z28
    Thank you for the reply. I've looked at the owners manual and can't figure out which fuse to pull.
    Probably the same as your dome lights.
    Dec 2010
    New York
    2000 Camaro z28
    Thanks Again. The only fuse I can see that's close to dome light is marked "COURTESY Body Control Module (BCM)" on the main fuse block. Would that be it?
    Shit I dont know...pull it and find out
    Dec 2010
    New York
    2000 Camaro z28
    I'll give it a try.
    Well after we execute this highly technical operation....then pull the switch and take the hot wire off the switch....plug your fuseback in. If it is OK then you got a bad switch.
    Dec 2010
    New York
    2000 Camaro z28
    Thanks again.
    Is it the switch?
    Dec 2010
    New York
    2000 Camaro z28
    Hi Sarge! I won't know until I get home. I was just trying to get an idea of what to do beforehand. I'll pull the courtesy and accessory fuses and see what happens. I'll let you know.
    Good man.
    Dec 2010
    New York
    2000 Camaro z28
    Well, Sarge, when I got home the latch had quit recycling. I haven't tried setting the alarm yet so I just shut the hatch and manually locked it. I thought I better leave well enough alone until it dries out around here. Here's a quick question: Does the little red light on the dashboard always flash or just when the alarm is loaded? I've never really noticed it before.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    ^^^ I believe so
    Quote Originally Posted by runhard View Post
    Yes.
    Pittsburgh
    2008 Hummer H3
    Deffinetly want to iron this out.. With the BCM fuse pulled many things will no longer operate. Such as power windows, wipers, radio, and so on.. Sounds like a bad release relay to me but the switch is also possiblely bad too..
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    ^^^ I believe so
    Yes it does, it should be a steady or "solid" light when the door is open with the engine off..
    Dec 2010
    New York
    2000 Camaro z28
    Thanks All. Well, the light is not on or blinking when the car is off. It comes on briefly when you start the car but then goes off. The hatch release is not recycling now and the car runs starts and runs OK but no light. We are just manually locking the car, not using the FOB. All fuses are back in. Any possibility that this is a weak or defective FOB?
    Pittsburgh
    2008 Hummer H3
    In that case I'd start looking @ a possible BCM issue which is common for us f-body guys, and or a possible VATS issue. just my .02
    BCM likely...
  1. Wanted Trunk Latch Switch
    By Nitro13 in forum Parts Wanted / Trade
    Last Post: 04-24-2016, 11:19 PM
  2. Rear latch
    By Agent421 in forum General Help
    Last Post: 08-12-2010, 01:55 PM
  3. Wanted: Safety Latch
    By SamD_Ind in forum Parts Wanted / Trade
    Last Post: 04-13-2009, 02:08 PM
  4. how much n where to buy for hatch/trunk latch?
    Last Post: 09-17-2007, 05:29 PM
  5. Firebird/Camaro Trunk actuator/motor/latch
    By Marc1130 in forum Parts For Sale / Trade
    Last Post: 08-15-2006, 06:09 AM
