Results 1 to 20 of 58
Thread: Humor me...
12-16-2010, 12:31 PM #1Impounded
- Apr 2010
- IN
Humor me...
Possible Swap?
yes i realize money...
this summer i'll be buying my some goodies (MWC 9", UMI LCAs, UMI Swaybars, UMI SFCs, Koni's, Strano's, etc. etc.)
So my suspension should be able to handle more power...
well being my car has 86,000 and will probably be close to 90,000 by the end of summer. ive been looking around...
looks like a fan favorite are the LQ4/LQ9..
well TSP has a GM 6.0L Cast Iron Block for $750
yes i know...cast iron is heavy and will add some 85-90lbs
but i read where this will work with my headers for my LS1 and that its a pretty easy fit in our cars.
whats your thoughts? Opinions? or other ideas or suggestions?
12-16-2010, 03:59 PM #2
Dont go by what others thing do what you want in your car how or whatever application you want your car best for, and you being 17 how do you afford these things?
12-16-2010, 05:32 PM #3Impounded
- Apr 2010
- IN
well.. ive always been a car freak.. so ive always worked to save for a car
so ive worked since i was 13 (around my grandparents farm) and then i got another job on top of that so i had two jobs for the past...4 years.
well my parents bought me a firebird for my xmas/16th bday present being my bday was 8 days after xmas
well i totalled that last february and insuence gave me almost $7000 (they paid 4500).
i bought my TA for $9200...then i had a gurl back into me causing an estmated $3000 of cosmetic damage well it ended up only costing $2200
...blind luck basically
and im basically going by whats the best value in terms of HP to $ to easy of install
but im still debating on all the possiblilities...who knows... i might sell this and buy a newer WS6 or something else...im constantly changing my mind...Last edited by BashamWS6; 12-16-2010 at 05:37 PM.
12-16-2010, 05:44 PM #4Senior Member
- Apr 2008
- Madison, WI
So technically all your money should be going to pay an unbelievably high car insurance rate...with all those resent accidents and the fact that you drive a high risk car at a "high risk" age group.
Just giving you a hard time.
Now to answer your question, I would only go to the iron 6 LQ4/LQ9 if you can justify the weight penalty. What I mean is, if you're gonna make BIG power, then go for it.
12-16-2010, 05:46 PM #5
I'd just beef up the LS1, forged internals and a bore...good luck holmes
12-16-2010, 05:48 PM #6Impounded
- Dec 2007
- SAN FRAN SISCO BABY
VW BEETLE W/ FLOWER- 88 CRX
your 17, your mind will change a lot more before you make up your mind.
cam it, do some wheels 224R 228R no bigger please. do LOTS of handling improvement mods you will be happy you did! and as i always say..install SUB FRAME CONNECTORS FIRST! save your car some hard times and do it a flavor.
good luck on any decision you choose though..enjoy the car. just not to much lol
12-16-2010, 05:58 PM #7
12-16-2010, 06:03 PM #8Impounded
- Apr 2010
- IN
well the first wreck only raised me like $100 per 6 months...and the second wasnt my fault so... tickets would be a bad thing for me but luckily my deferals have saved me except i got an unsafe start on my record now (which was crap...the s10 and civic in front of me didnt get pulled over for their peel out)...so that push it up again... but the thing is...my insurance is better than any of my friends...and theyre driving suvs/trucks/v6 4door cars...so ive been lucky again.
as for big power. of course thats what i want haha.
but i want an engine that will take my headers too being theyll only be a year or so old when i get the swap. weight. i can easily shave 90lbs in the car (jack and spare and racing seats etc.....and my hood is aftermarket thanks to wreck so i already shaved 20lbs there)
but the reasons im leaning to the 6.0L is because it can take up to 10lbs boost right off the start because its iron and its $750 for the block...of course idk if a tunrkey engine would be a better value...
my question is...what would be the way to go if i was looking for the following:
easy install---no BFH needed
horsepower to money ratio
work with my LS1 Kooks 1 7/8 headers
work with alot of the same LS1 set up
but something that i havent thought of...gas mileage...id like to keep it around the same
some threads i looked at say go with a built up LS1...but i feel like i could get more stock HP with a bigger CI engine thats stock for now and the build up on that...
12-16-2010, 06:08 PM #9
12-16-2010, 06:10 PM #10
12-16-2010, 06:17 PM #11Impounded
- Apr 2010
- IN
Cutlass...is that for all the engines at TSP? or are their exceptions? im new to swaps
and by HP to $ ratio i mean whats the biggest bag for my buck...
im just looking for a bigger engine that will work with alot of ls1 components so i dont have to completely swap everything under the hood.
i figure that fuel/wiring/oil systems and a tune wll be necessary
12-16-2010, 06:21 PM #12Senior Member
- Apr 2008
- Madison, WI
The LQ4 and LQ9 are in the Gen III LS series of engine. So it is physically identical to the LS1 in your car. All exhaust, motor mounts, and every other engine accessory will bolt up exactly like your LS1. Its a no brainer swap
12-16-2010, 06:23 PM #13Senior Member
- Apr 2008
- Madison, WI
But if you plan on dropping in a stock 6.0, you're gonna make your car slower. Its heavier and its horsepower is the same or less then your current LS1
12-16-2010, 06:42 PM #14
12-16-2010, 06:50 PM #15Impounded
- Apr 2010
- IN
would TSP's 427 cid LS3/L92 Aluminium Stroker Short Block work?
or should i go with 6.0L iron block with a 408 CI rotating assemblies, LS6 intake, LS6 oil pump, better than 26lb fuel injectors, and a good set of heads and maybe a small streetable cam...looking at about $6k-7k?
or am i ignorant here?
12-16-2010, 07:18 PM #16Slow'er'Ass
- Thornton, CO
Not ignorant.
Just not up on what those kind of motors require or cost.
12-16-2010, 07:25 PM #17Impounded
- Apr 2010
- IN
know of any good write ups then? ive been searching but apparently im missing...
12-16-2010, 07:28 PM #18Slow'er'Ass
- Thornton, CO
Suspension, rear, motor, tires, maintenance...
I have well over $20K into mine. Motor is around $10K itself.
12-16-2010, 07:37 PM #19Impounded
- Apr 2010
- IN
...well...haha but your trans am is a beast...
i was looking at the more subtle solutions now and the build up as my budget allows me...
12-16-2010, 07:42 PM #20Impounded
- Dec 2007
dont try and make it a drag car you will NOT be happy with it. i promise a mild cam wheels tires and all the suspension upgrades will bring such a big grin to your face each and EVERY time start her up
dont make the same mistakes so many others do and go over board with a DD
Military Humor
By robcas47 in forum Military MembersReplies: 1Last Post: 11-10-2010, 09:17 AM -
Some UPS Humor
By SMWS6TA in forum Almost Anything GoesReplies: 19Last Post: 08-25-2010, 10:12 PM -
A little humor
By KahanaReef in forum Political / Debate ForumReplies: 9Last Post: 07-13-2010, 04:54 PM -
Look if you have a sense of humor
By 01ws6er in forum Almost Anything GoesReplies: 10Last Post: 05-10-2009, 07:52 PM -
Rice Humor
By RainMan in forum Almost Anything GoesReplies: 8Last Post: 04-12-2006, 08:34 AM
