Results 1 to 2 of 2
Thread: Throwing a p0343
12-16-2010, 09:12 AM #1
Throwing a p0343
I went to get tuned last nite only to have proplems. It cranks then dies when the 100mm maf is connected. I unug the maf and it runs fine. But still has the code. I have the ls1 computer with a ls2 engine so I swapped the outside wires today. I also pulled the sensor out and there are no signs of contact between the sensor and the gear. Can anybody help
12-19-2010, 09:23 AM #2
Look at dynamic airflow and see what the g/sec consumption is. Try and run with the MAF and see what frequency range is reported. Go back to that frequency range on the MAF table and make sure that the value is close so that you know you have enough fuel to support combustion. If it won't run, setup the tune in SD but leave the MAF connected so that you can see it's reported frequency.
I think I said this on another board as well but... that code can mean that your cam bolts have backed out and the cam has walked a bit. I have seen this several times over the years. If that IS the case you will want to know ASAP before you end up with something hurt.
P0343 DTC P0343 Camshaft Position (CMP) Sensor Circuit High
By Camaro98Z/28 in forum General HelpReplies: 11Last Post: 10-16-2013, 07:57 AM -
Help: P0343
By Boothe in forum Firebird / WS6Replies: 3Last Post: 05-03-2012, 09:23 AM -
Help: dtc p0343
By 05silverado in forum GM TrucksReplies: 2Last Post: 12-19-2011, 05:11 AM -
Help: Throwing an Obd code the First day with it!!!
By Justin93 in forum General HelpReplies: 10Last Post: 06-24-2008, 10:20 AM -
Need help, throwing codes!!!
By rotwiler in forum Computer & TuningReplies: 2Last Post: 07-13-2007, 08:44 PM
