Thread: compressor oil
    Member nuttyprofessor's Avatar
    New Jersey
    compressor oil
    my ingersol rand compressor calls for mobil rarus 427 compressor oil. Anyone know of a suitable alternate? just looking to get something readily available from an auto parts store.
    thanks
    I just went and looked at mine -- I am running the All Season Select Ingersoll Rand oil in my 80 gallon IR Compressor. The bottle indicates that it is recommended for all their compressors, except two (2) older models and the rotary screw type. I take it yours is a rotary?
    Member tpilews's Avatar
    Tampa, FL
    '98 Z28
    Any kind of non-detergent oil will work.
    Junior Member MRWHOOPPEE's Avatar
    Jun 2006
    san jose
    86 &99 Z51's
    I just use Mobil 1 10-30
    Dec 2020
    pakistan
    2020 civic
    Cool Best air compressor oil
    The best air compressor oils can make a huge difference in the durability of your compressor, as well as in the ability to start in cold weather.
    Like most engine-powered machines your air compressor motors require lubrication to keep them operating efficiently and minimize the impact of wear and tear, as well as to cool and seal internal engine components.
    Proper lubrication can also reduce your energy costs. By decreasing friction, lubricants reduce heat and lower the compressor’s energy intake. So, many air compressors need oil to run properly.
    If you have never changed the oil of your compressor or you didn’t know you need to, your first question will be what kind of air compressor oil should you buy?
    So, in this article, I reviewed the Best Air Compressor Oil along with pros and cons which will help you in selecting the best oil for your compressor.
  1. looking to buy air compressor
    By 28Marcos in forum Tools
    Last Post: 01-28-2011, 10:11 AM
  2. new air compressor
    By Zboner in forum Tools
    Last Post: 07-29-2009, 07:33 AM
  3. Air compressor
    By tpilews in forum Tools
    Last Post: 09-19-2007, 05:53 PM
  4. Need an AC Compressor
    By TwistedSS in forum Parts Wanted / Trade
    Last Post: 03-20-2007, 12:09 PM
  5. New A/C compressor
    By fastbuff in forum Corvette
    Last Post: 01-13-2007, 06:09 AM
