Results 1 to 18 of 18
Thread: painting slp lid
11-06-2010, 05:59 PM #1Member
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
painting slp lid
who all has painted their slp lid and what kind of prep work and paint did you use?
11-06-2010, 08:15 PM #2
Get a greay scotchbrite from auto parts store and use some water and dish soap with degraser like dawn. The clean with a wax/grease remover also found at most auto parts stores. Then some Adhesion promoter/ Duplicolor is good. Then get primer white, grey, or dk grey depending on the color it is being painted. After the primer just paint and clear coat.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
11-06-2010, 09:12 PM #3
11-06-2010, 09:23 PM #4
I used high temp gloss black engine paint then a clear coat......turned out great.....no sand or primer
11-06-2010, 09:50 PM #5Slow'er'Ass
- Thornton, CO
Sand. Whatever it took to get that fucking SLP logo off.
Wetsand to 600 grit.
Two coats. Wetsand with 2000 grit after dry.
Two more coats.
Let sit a week.
Used stencils, taped off letting.
Obviously wiped off lid to make sure clean.
Three light coats.
Waited about an hour. Removed stencils.
Sprayed clear (two coats).
11-07-2010, 09:02 AM #6
Agree, ..., sand like hell to remove the SLP imprint.
If you have access to a nice DA or most any electric sander, it'll help make it a quick job.
Wash, wash, wash, ..., clean it very well, wipe with a wax & grease remover if available.
The dishwasher helps too! Just don't let the wife know, ...
Prep is key. A good adhesion promoter helps. If you're using the spray can method, the Fusion product isn't too bad. A good heavy-fill primer will help also & you can do a quick wet-sand with 1500-2000 grit to help smooth it all out before any color coat.
Some examples:
But these are done at an auto-body shop, not rattle-can.
If you're doing a basic black, stop by your local auto-body shop & see what your guy would charge ya. If color-matched stuff may not be too extreme if ya find the right guy to work with.Last edited by PontiacFan; 01-28-2011 at 12:33 PM.
11-07-2010, 12:33 PM #7Member
- Nov 2009
- North Carolina
im thinking about painting my lid to match the stripes on my car. if you go to my home page you can see the stripe scheme i have on my car how do yall think it would look if i copied that on the lid so when i opened my hood i would have the same color and width stripe as what is directly above the lid on the hood
11-07-2010, 12:39 PM #8
da'ed with 320
wiped down with 159 plastic prep
adehesion promoted
then primed
sanded primer with 400
156 prepped
sealed
based 8776 red
cleared
all sherwin willams products
11-07-2010, 02:50 PM #9
looks good guys
11-07-2010, 06:12 PM #10Impounded
- Apr 2010
- IN
well if you didnt want to paint a logo... im sure third shift could get u design
11-07-2010, 06:44 PM #11
Looks clean, have so say I am impressed using sherwin Williams paint, only reason I say that is I worked for a company that used their products and sprayed my bumper over and only took 2 its for the clear to chip and flake and I know it wasn't the prep since I painted my hood a month later with dupont and it still is on there. I.just sprayed my ls6 intake the same color but with all PPG usually I'm a dupont person since it's little cheaper and same quality.
11-08-2010, 07:09 AM #12
11-08-2010, 11:16 AM #13
11-08-2010, 04:55 PM #14
11-09-2010, 10:44 AM #15
11-09-2010, 06:02 PM #16
very reliable i been spraying months now no problems ... actually bill over in the eastern dragstrip thread has the same setup as i and he sprayed a stockbottem end ls1 for over 4 years with no problems... on 150shot
11-09-2010, 10:36 PM #17Junior Member
- Jan 2007
- dallas texas
white- 1997 sierra
i wish i could upload pics i would show mine.
cleaned it with soap and water, break clean, 280 grit wetsand, then 1000 grit wetsand, then painted 3 coats of dark cherry red metallic, and 4 coats of clear. reason for color is because im color blind and thought it was black hahaha. if someone wants to upload them give me email and ill send them
11-10-2010, 07:25 AM #18
Question: painting
By 99ss in forum Appearance SectionReplies: 5Last Post: 07-28-2010, 11:18 PM -
Painting With Waterborn Paint - Painting With Wate
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 06-17-2010, 02:00 PM -
Retro Stripe Painting - Painting Homage
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 06-17-2009, 10:10 PM -
Help: painting air lid
By Justin23454 in forum Appearance SectionReplies: 9Last Post: 12-23-2008, 10:27 AM -
Painting HELP!!
By Blownone94 in forum General HelpReplies: 8Last Post: 04-11-2008, 04:43 AM
