Thread: Package deal any good?
11-03-2010, 11:04 AM #1
Currently I have full exhaust, intake, tb and tuned I have no suspension work on the car yet....I plan on doing suspension work this winter are the package deals any good for these cars? For example bmr has lowering springs panhand, strutower brace, control arms, sfc etc etc for like 1100 bucks..am i better off buying each individual piece separate or the package deals are worth it on these cars I dont take this car to the track at all but i do plan on putting cams and heads in eventually over time....I dont mind spending extra money I jsut want the car done right... if anybody has bought a package deal which one did u use how did u like it?? Thanks in advance!
11-03-2010, 07:49 PM #2
do you want the car to be on rails around turns or do you want it to go fast in a stright line?
do you need a nice quiet ride or can you put up with some bumps and a little bit of noise?
11-03-2010, 10:38 PM #3
get strano springs......
11-04-2010, 02:20 PM #4Junior Member
- Sep 2007
- Fort Wayne, IN
Red- 2002 Chevy Camaro SS LE
Suspension
As previously posted it depends what you want to do with your car. I have had excellent results with Strano Performance parts. I spoke to Sam Strano several times before buying my first suspension parts.
Good Luck.02 Camaro SS, 35th Anniversary Limited Edition #1021, 6-speed, T-Tops, 345HP SLP option, CME, 3.73's, J&M LCA's, UMI 3-pt SFC's, Strano springs, KONI SA's, Strano 35mm front sway bar, Hellwig adjustable rear sway bar, Hawk HPS, UMI adjustable PHB
11-04-2010, 06:02 PM #5
Id kinda liek the best of both, an equal balance of the two i really just dont want the car to twist I have stock size tires on the car with good tread and i still have trouble hooking especially from a slow roll or stop.....I would def liek the car as quiet inside as possible with no noise but the exhaust lol
Dan u also told me 2 get the umi sfc so goin separate its prob a better result in the end....ima most leikely get the 3 point sfc
11-04-2010, 08:18 PM #6
UMI suspension parts are great
11-04-2010, 09:28 PM #7
here's the compromise I found from my own experience. rod ends will give you great handling but are noisey on bumps and beat the hell out of you. polyurethane give slightly smoother ride then rod ends but bind up under agressive turning.
heres what I would suggest..
- LCA: on car adjustable, rubber bushing/ rod end combo.
-LCA relocation brackets
-PHB: on car adj. rod ends.
-adj. transmission mount TA
-trans mount w/ TA relo. bracket
-3 point SFC
-tunnel brace
-adj. rear sway bar
-(UMI) front sway bar
-strano springs
-koni or SLP bilsteins
11-07-2010, 03:55 PM #8
Found this Head and Cam Package Deal
By doozjamann in forum Internal EngineReplies: 3Last Post: 07-21-2008, 12:41 PM -
Rebel XT package deal
By ninobrn99 in forum General ClassifiedsReplies: 0Last Post: 01-22-2008, 09:39 PM -
3 Cars Parted Out - Lots Of Good Deals - Will Make Package Deal For It All !!!
By LS1W in forum Parts For Sale / TradeReplies: 21Last Post: 12-02-2007, 04:45 PM -
SLP header package.....good deal?
By undertow74 in forum External EngineReplies: 5Last Post: 10-06-2007, 07:11 PM -
2000 ws-6 parts package deal!
By 1slo5oh in forum Parts For Sale / TradeReplies: 13Last Post: 05-03-2006, 02:10 PM
