Results 1 to 15 of 15
Thread: Question About the GTO's A$$ end
11-03-2010, 12:16 AM #1
I would like to install a taller set of gears and don't know what to shop for. EX... 12" rear end, 6 bolt? I have no idea. Also I hear a clunking sound from the rear. Nothing is loose. I had the same sound when I had my 00 B4C. Thanks for any help you can give me.
First Tank!!!
11-03-2010, 07:50 AM #2
That clunking could be from the ring and pinion have a large gap. My GTO did that if I would go from reverse to forward. It had a lot of play in it, most are known for it after a while.
I think that the Lumina SS (same as GTO in middle east) came wit 3.07or something but not sure.
11-03-2010, 09:49 AM #3
Stock gears in all Gtos are 3:46. Use the search or the net and you will find a lot of info. Good luck
11-03-2010, 10:04 AM #4
- Mar 2009
- indianapolis
PBM 366ci TC78 E85- 2004 Pontiac GTO PBM A4
GFORCE engineering will be a good place for you look up. and the stock diff is kind of known for issues.
11-03-2010, 02:49 PM #5
- Jan 2009
- North Jersey
I would STILL love to find out how some of these GTOs in GMHTP with larger cubes or forced induction STILL run on the stock rear. IMPOSSIBLE!!!
11-03-2010, 04:36 PM #6
11-03-2010, 04:42 PM #7
Exotic Performace Plus has a moser M9 straight axle that will bolt in for 4k, Take a look, it is very cool!
11-03-2010, 06:42 PM #8
11-04-2010, 04:25 PM #9
11-04-2010, 06:39 PM #10
Look at the GTO ET list and qwkgto ran a twin turbo set up 9.52 @ 144 1.55 60 ft on a stock rear!
11-05-2010, 10:57 AM #11
408 stroker with built tranny and 3,800 stall here...89,542 miles, still running my stock rear
11-07-2010, 12:26 AM #12
11-07-2010, 08:16 AM #13
- Jan 2009
- North Jersey
Check your U-joints in the driveshaft as well.
11-07-2010, 03:05 PM #14
11-07-2010, 05:39 PM #15
- Oct 2010
- Scottsburg, Indiana
Cosmos Purple- 2004 GTO
I replaced my stock 3.46's with 3.91's after I ate half the teeth off the non shot peened 04 pinion gear. Bow my 3.91's are clunking while under light to moderate load. Heavy load or clutch pushed in the clunking goes away. Yay for "stock" rear ends
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
