Thread: Adding traction control
11-01-2010, 08:59 AM #1
My last f-body had traction control. I got a great deal on a 2000 SS with only 5900 miles on it, but it didn't have traction control. Can anyone give me a list of the parts needed to add traction control to my car? Thanks.
11-01-2010, 09:32 AM #2
First I have seen this question asked on here. My guess is that this is not only an involved swap, but a costly one at that -- axles, reluctor rings, backing plates, wheel sensors, wiring harness, switch... just to start. I'm not sure how your car is configured, does it have a dual circuit rear brake setup? Does the brake block and/or antilock system need swapped? What about the controller for the system?
11-01-2010, 10:04 AM #3Exalted Cyclops
- Feb 2007
- San Diego, CA
My question is why would you want it in the 1st place???
Back in the good old days Traction Control was excercised between your brain and right foot...
11-01-2010, 10:21 AM #4
11-01-2010, 10:21 AM #5O U 8 1 2
- Nov 1999
- over here...
the traction control on our cars is the most crappy set up ever made... if you want TC you're probably better off buy a car with it on...
11-01-2010, 10:23 AM #6
11-01-2010, 11:00 AM #7
Want it because it saves on tires. Need info NOT comments.
11-01-2010, 04:08 PM #8Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
PAJeff has it right (axles, reluctor rings, backing plates, wheel sensors, wiring harness, switch) all are needed to switch from a 3 channel to 4 channel ABS. Add to that the extra cables and TCS Coupler. It was a $495 option but will cost alot more to replicate now.
IMO TCS is nothing but a common sense inhibitor. Never had it and never needed it, even in the snow.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
11-01-2010, 04:45 PM #9
not to mention a new ebcm or have your current one reprogrammed but on a 2000 there is prolly no reprogramming seeing how the dealer will have to order one with acr preprogrammed. my guess a new ebcm ~$900 my z doesnt have it and i dealt with a wyoming winter and didnt need it.
btw common sense will keep you from ruining your tires better than a damn ebcm
11-02-2010, 08:07 PM #10
isnt he better off and cheaper to just buy a whole 4ch rearend?
11-02-2010, 09:16 PM #11
11-03-2010, 03:57 AM #12
now that you aare guys are talking about TC. Can I use TC axles on a rear end that doesn't have TC? i'm trying to get some axles and I get a good deal on some used ones but they told that they were for TC. Thanks
By Whamhammer in forum Firebird / WS6Replies: 14Last Post: 11-26-2013, 04:28 PM -
Adding Cruise Control
By kermits8 in forum General HelpReplies: 2Last Post: 07-09-2010, 01:16 PM -
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-17-2010, 12:57 AM -
By Merlin in forum General HelpReplies: 6Last Post: 05-07-2006, 11:22 AM -
Traction Control
By daryl.l in forum Firebird / WS6Replies: 4Last Post: 03-05-2006, 02:05 PM
