    Member 173rdbrandon's Avatar
    A, A
    2000 Trans Am WS6
    Stupid VATS! Easy question
    Vats have finally possible taken a crap on me. put key in, security light flashes and no start. Same with other key. Took key and put it to a digital multi meter on the 20k setting and got 0.523 . so my question is what resistor do I get? radio shack wasnt any help when I told them this. do I just get a half watt resistor or what? any help would be great. Thanks
    Jul 2010
    Navy Blue
    1999 Camaro Z28
    A, A
    2000 Trans Am WS6
    Yes I have seen this thread. My question is what resistors do I get to achieve this 0.523?
    A, A
    2000 Trans Am WS6
    Do I just need a 523 ohm resistor at like a half watt? Or out of a series make 523?
    Georgia
    red black
    98Z28
    http://www.vatskey.com/vats/lostvatskey.htm Look there, but what you need is a 500 ohm resistor. There is a +or- 15% tolarance.
    A, A
    2000 Trans Am WS6
    got it working!!
    glad you got it figured out......you want to get as close to that 523 as possible due to the variance as listed above. Also if you use gold band resistors your variance is only 5% instead of 10% with the silver.
    Quote Originally Posted by 173rdbrandon View Post
    I always recommend a half watt....you can get away with the quarter if your up the chart a ways but down low it's getting close. I explained it in the other thread which I'll quote here. What I don't know is if that vats module is operating on 12v so this could be wrong but it's on the safe side. I'm kinda assuming here that the module is operating on 12v.
    it really depends on what key pellet you have but the short answer is if you want to be safe go with the 1/2watt. The quarter watt will work on the majority but I'll give you an example using the lowest pellet resistance.
    ohms law is P=I*V which is power=current*voltage
    you have to solve for current first which is I=V/R
    lowest pellet resistance possible is 386ohms
    12v/386ohms=.03amps
    .03amps*12volts=.37 watts so P=.37 which is a little over a quarter watt.
    A, A
    2000 Trans Am WS6
    Ya I made a half watt 526 ohm resistor with a 5% tolerance and works great
  1. Quick and easy gun question...
    By nitrox28 in forum Gun's & Ammo
    Last Post: 07-12-2010, 09:00 PM
  2. Question: stupid light stupid question
    By TAallday in forum LT1
    Last Post: 08-26-2009, 10:58 PM
  3. Very easy question
    By crapyboy750 in forum General Help
    Last Post: 02-05-2009, 02:34 PM
  4. vats question....
    By 0rion in forum GTO
    Last Post: 08-12-2008, 11:07 AM
  5. MONSOON@@@@@ please help easy question!!!!!
    By ls1kid20 in forum Stereo and Electronics
    Last Post: 07-22-2006, 06:41 PM
