    Orlando
    red/black
    97 Firebird
    changing posi lube
    going to do a flush of posi unit,son works at a mobil kwik lube,
    and hes suggesting removal of all old lube and replacement with mobil synthetic gear lube.
    Do I need to add GM posi additive?
    rear has about 60 K on it now and posi unit acts just fine.
    Here for entertainment 502ci's Avatar
    Ohio
    97 6-speed corvette
    Does the mobil synthetic say it has a limited slip additive? If not you must add it.
    Orlando
    red/black
    97 Firebird
    dont know will check and see.
    Since this is a store that is franchised by Mobil I would think
    they know but i do know that some reports in past of using
    conventional hipo gear oil has said it didnt need additive but in fact
    GM posis did act up and cleared right up with one or 2 bottles fo supplement.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    Yes you will need the additive no matter what fluid you choose.
  1. Torsen posi lube and additive?
    By Ortiz11b in forum Drivetrain
    Last Post: 08-23-2011, 06:25 PM
  2. aburn posi vs eaton posi units
    By TOOSHORT2000TA in forum Drivetrain
    Last Post: 04-05-2009, 06:01 PM
  3. What type of lube?
    By state69champ in forum Almost Anything Goes
    Last Post: 04-25-2008, 01:40 AM
  4. Oil & lube
    By Blackout01 in forum General Help
    Last Post: 05-23-2007, 08:56 AM
  5. Lube Job??
    By thugtilidie18 in forum General Help
    Last Post: 05-22-2007, 10:20 AM
