Results 1 to 11 of 11
Thread: Thought's On TSP Tsunami?
10-20-2010, 03:34 PM #1
Would This Cam Be Good For My Application?
I need to know what you all think about TSP Tsunami cam.
I am looking for a cam for my 02 WS6 with full exhaust and a 4000 stall that would make my engine capable to run Mid-Low 11 second set up on 243 and high 10's with a good set of head's without killing the driveability. It's not my daily driver but I do drive it on weekends cruising and sometimes during the week.
Tsunami Spec's: 235/240 .648/.609 111 LSALast edited by Mesterious; 10-21-2010 at 03:41 AM.
10-21-2010, 03:07 PM #2
I think it is a bit big for what you want and if you don't have an excellent tuner, you can kiss drivability good-bye with that one...
I ran 11.4's in mine when I had a stock set of 243 heads and a 228/232 cam with a 3,800 converter...
If the car is put together right, you should be able to meet your goals with a TSP magic stick 3 and a good set of thier heads... those cams with the high intake lifts are hell on valve springs too...
GM EFI Tuner
2002 Trans Am WS6 - 9.41@143mph, #3675, on pump gas and drag radials - sold
10-21-2010, 04:03 PM #3Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
the only reget I have is not going with that cam, if you have the tuner to make that cam drivable then I would say go for it.
10-25-2010, 05:45 PM #4
Does anyone here have the tsunami or have a friend with results of the tsunami?
11-21-2010, 08:20 AM #5
I have this cam w/ ls6 heads. 420 rwhp daily driver and fine even in traffic.
11-21-2010, 08:45 AM #6
11-22-2010, 02:55 PM #7
Head/cam package
http://www.texas-speed.com/shop/item...d=680&catid=47
This is the heads/cam package I got. I included the oil pump and double roller timing chain as well. Chose tsunami 235/240 cam. Installed headers, a Z06 maf and lid. Did not get the intake - I should have. That would be my next upgrade. Went from 320 rwhp with just SLP exhaust to 418 rwhp with above setup. (Was 98 degrees and 85% humidity in San Antonio Tx during dyno tune.)
Get the intake
11-29-2010, 03:11 AM #8Member
- Jun 2008
- Oregon
Gold- 1998 Camaro Z-28
I have afriend that did the Tsunami cam and TSP LS6 2.5 heads. he got 424whp on a mustang dyno. His car is a 6sp also.
This vid was taken with my droid X
[ame]http://www.youtube.com/watch?v=QxZ-3xX0PDg[/ame]
And his dyno video I made
[ame]http://www.youtube.com/watch?v=YjOCJEyjVPg[/ame]
I personally have not riden in his car but it sounds sick.Last edited by goldz28; 11-29-2010 at 03:26 AM.
12-19-2010, 08:25 PM #9Junior Member
- Dec 2010
- India
golden- Maruthi Zen
I have a 2001 Pontiac Trans Am WS6. With a whooping power of 325 hp at 5200 rpm, the V8 beast goes from 0-60 mph in 4.9 seconds. The 6-speed transmission is superb as well. Recently, I installed the 235/240 .648/.609 111 LSA Tsunami Camshaft with 237 heads and it amazed with me with a very high performance. A weekend cruising will be great on such a machine. Tsunami camshaft is a high-performance unit, so it is going to be a little harsh on the springs.
12-19-2010, 08:45 PM #10Slow'er'Ass
- Thornton, CO
Local shop has a variation of that cam in several cars running around here.
I would take that cam over a MS3/MS4 for a street application. Apparently fairly easy to tune and can be pretty driveable on the street. That isn't to say it won't surge once in a while, but it seems proven.
That said....650" lift is insane on valvespring life. Consider that normal maintenance at 25K miles with that cam.
12-24-2010, 08:38 PM #11Member
- Jun 2009
- coon rapids, MN
red- 2000TA
EPS baby cam,222/226 in stock ls6 runs 11.30.you don't need the biggest cam to move the quickest.
Japanese Tsunami from inside car vid
By 28Marcos in forum Almost Anything GoesReplies: 8Last Post: 08-06-2011, 03:44 AM -
TSP tsunami cam+ what heads and other mods?
By PFCTTZZ in forum Internal EngineReplies: 7Last Post: 12-26-2010, 11:24 PM -
2.5 ls6 + tsunami
By Darkrider02 in forum General HelpReplies: 7Last Post: 12-11-2010, 08:25 AM -
2.5 ls6 + tsunami
By Darkrider02 in forum Internal EngineReplies: 0Last Post: 12-07-2010, 07:03 PM -
Another Tsunami ?, breaking news
By Danger731 in forum Almost Anything GoesReplies: 2Last Post: 12-26-2006, 06:34 PM
