Results 1 to 1 of 1
10-20-2010, 01:50 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
How to Make a Carbon Fiber Sub Enclosure
When I decided to update the install on my car I wanted to make a carbon fiber sub box to match the all the carbon fiber on the car. I also wanted this box to be as light as possible. I took a piece of 12-inch PVC left over from another project and decided to use that for the box shape. This enclosure is made from 6061 aluminum, carbon fiber, and a little epoxy to hold it all together. —Thom Voisinet
1 & 2. Since I knew the radius of the PVC, the outer size was easy to figure out. I then drew up a few braces using a square, adjustable angle finder, and some Mobile Solutions templates. Once the final MDF brace template is done it can be transferred to aluminum on the router table. I'm lucky enough to work with someone who could transfer my design and CNC it, so they were all perfectly symmetrical.
3. For the face of the enclosure I used 1/4-inch 6061 and cut it on the table saw. I cut an angle on each side, as close as possible to the angle the carbon meets it.
4. Two holes were rough-cut with a jigsaw for a Polk Audio MM1040 woofer. I then used an MDF template to cut perfect holes on the router table.
5. A small landing arch (slightly smaller in diameter than the end cap) was glued to the end cap. This provides a spot for the carbon fiber to be glued to the aluminum.
6. Squares and clamps were used to ensure the end caps were straight.
7. More clamps and pieces of MDF were used to attach the braces.
8. A 1/2-inch square aluminum rod was glued to the back of the face for a spot to glue the carbon fiber. Duramix panel bonding epoxy was used for all aluminum/aluminum attachments.
9. Nineteen-ounce dry carbon fiber weave was taped to the PVC then wet-out with surfboard resin. A second and a third layer of 19-ounce carbon weave were added and wet-out as well.
10. Multiple coats of resin were added on top of the third layer of carbon fiber to ensure a flat surface after sanding.
11. A dual-action sander and a long board were used to sand the resin as flat as possible.
12. The carbon fiber popped off the PVC very easily since I waxed the PVC before taping the first layer of weave to it.
13. I rough-cut the carbon fiber with a reciprocating saw, using MDF as a template.
14. After rough cutting, I fine-tuned the cuts with a dual-action sander using MDF as a template once again.
15. With the carbon fiber cut to size, I used Duramix universal adhesive to bond the carbon fiber to the aluminum. Ratchet straps were used at all brace points until the epoxy cured.
16. The end caps were marked for the mounting braces. I taped two holes in the aluminum for bolting pieces of the old strut tower bar, which then bolts to custom steel plates on the floor of the car.
17. To finish the aluminum, I started by sanding out all the deep scratches, then progressively moved up to 3,000-grit before using a polish compound. Spraying water helps to keep the aluminum cool while sanding.
18. The aluminum was masked off to protect it from being scratched, and automotive clearcoat was sprayed over the carbon fiber.
19. Once cured, the edges of the clearcoat were sanded smooth. The clearcoat was then buffed and the edges of the aluminum were polished.
20. The MM1040 10-inch woofers fire toward the rear deck of the car. Both the woofers and the box weigh in at less than 50 pounds total.
21. The carbon fiber and polished aluminum match the carbon throughout the car and aluminum rear triangle brace in the trunk.
More...
How to Lay Up Carbon Fiber
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 11-06-2012, 10:10 AM -
Carbon Fiber before and after.
By 2tuff4u in forum Showcar and DetailingReplies: 29Last Post: 04-10-2012, 08:58 AM -
Question: Carbon Fiber
By Torqueless in forum Appearance SectionReplies: 30Last Post: 04-19-2009, 11:00 AM -
carbon fiber lid FS
By TransamDemon2000 in forum Texas MembersReplies: 1Last Post: 01-29-2008, 03:58 PM -
Carbon fiber
By robbzemail in forum Firebird / WS6Replies: 23Last Post: 10-13-2006, 09:58 PM
