    Millennium Falcon mpfranks's Avatar
    Akron, Oh
    2000 Trans Am WS.6
    t56 rattle. HELP trans guys!!!
    ok so heres the deal. went to pull out of my garage this morning and noticed and unusual sound. i would describe this sound as a metal on metal, tinny, from the tranny and rattling. seems like possibly a bearing. only does it when the car is in gear. notice it even more when coasting in gear, goes away slightly under a load. goes away completly when the clutch is depressed. the clutch was replaced at a dealer in 2007 at 16,700 miles and now only has 25,550 miles. dont reallly drive the car hard. really not sure where to go from here.
    throwout bearing? pilot bearing? or input shaft bearing? something else?
    thanks in advance.
    sounds pretty much like this.
    [ame]http://www.youtube.com/watch?v=7WWQrl8PMMk&NR=1[/ame]
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I'd guess it a simple throw out bearing noise from your description.
    Akron, Oh
    2000 Trans Am WS.6
    but the slave was replaced with the clutch, so wouldnt that have been changed too?
    Madison, WI
    2001 Silverado Z71
    yes it should have been. Most slaves come with the bearing. The GM one does. Did they use a GM slave cylinder?
    Only way to tell for sure is to pull the transmission out and check the bearing
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Cutlass...I remember reading that although the throwout bearing could possibly be making noise...it didn't necessarily mean it had to be changed and it could still survive a while.
    Any truth to that?
    Madison, WI
    2001 Silverado Z71
    ^^Yep.
    Even if it was changed, doesn't mean it couldn't have failed prematurely.
    Akron, Oh
    2000 Trans Am WS.6
    they used all gm parts. so im assuming it was changed. and it sounds just like the video i posted before. isnt that the clutch release bearing?
    Madison, WI
    2001 Silverado Z71
    yep. Clutch release bearing and throwout bearing are the same thing.
    Akron, Oh
    2000 Trans Am WS.6
    good to know. so i guess what i need to know is what brand bearing should i get?
    Madison, WI
    2001 Silverado Z71
    well despite your problems with it, the GM one is a good quality one. But you can get a good one about anywhere
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    My brand new GM throw out bearing began making noise within a month after it was installed. Annoying as all hell- I hear it everytime I press in the clutch and every time I sit in neutral with the clutch out. Biggest PITA but I'll hold out replacing it until next summer when I upgrade the transmission. As long asits only squeaky you're okay- it's when it really starts making noise and grinding that you have to worry!
    2000 Pontiac Firehawk #0041 of 742
    Akron, Oh
    2000 Trans Am WS.6
    confirmed! it was the throw out bearing. changed it over the weekend. i went with a timken bearing for only $56. thanks for all the help guys.
  1. Help: 2000 Trans Am Slight Rattle
    By Pj Klingler in forum Firebird / WS6
    Last Post: 01-19-2016, 04:00 PM
  2. Help: any trans guys here?
    By 383ls6 in forum Automatic Transmission
    Last Post: 11-14-2013, 06:11 AM
  3. Hey guys new to ls1.com **SOM Trans AM** (Pics)
    By SOMTRANSAM in forum New Member Introductions
    Last Post: 02-14-2012, 09:31 PM
  4. Any Trans Am Guys In Miami?
    By JOHN_DEERE_LS6 in forum Firebird / WS6
    Last Post: 03-03-2008, 07:31 PM
  5. question for trans am guys
    By kskevin in forum Firebird / WS6
    Last Post: 08-04-2006, 10:37 AM
