10-13-2010, 07:09 PM #1
Correct pinion angle tunnel mount torque arm
correct pinion angle is from -1 to -3 at maximum that means the rears pointed down and so is the drive shaft so upon load the drive shaft rolls and your driveline is in a perfect straight line... am i right... lol
maybe i just need the stronger driveshaft i just ordered...
or the adjustment is still wrong..
somebody help lol i need advice
10-13-2010, 07:14 PM #2Slow'er'Ass
- Thornton, CO
How is it grabbing at launch?
Too much normally creates hop.
Too little normally creates spin.
http://www.ssz28.com/tech/Pinionangle.html
Broken DS's are from weak DS's or REALLY extreme angles.
10-13-2010, 07:17 PM #3
im on 28inch tall et street radials at 16psi on my 15 greg welds it hooks and doesnt spin at all....funny thing is i baby launched around 2500rpm and broke the lastest driveshaft which was saturday.... and i regularly launch from 3500 to 4500
10-13-2010, 09:11 PM #4Exalted Cyclops
- Feb 2007
- San Diego, CA
Maybe I should knock on wood cuz I haven't broken a DS yet. Plenty of stripped gears and burnt pinions and bearings though.
I'm set at a tad over -2* and the car dead hooks (that's what took the last set of gears even though I'm an A4) after a burnout stalled at 2500 on MT's.
I like the trophy rack...67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
10-14-2010, 07:31 AM #5
You look like you are still running the stock aluminum drive shafts. So I wouldn't blame their breakage soley on your pinion angle. I've seen those things twisted like prezels on bone stock cars and street tires.
In all honesty if you plan to race the car that much and launch at those rpm levels, you should really step up to a stronger piece. For very little money you won't have this headache, and take a chance also of taking the transmission or your rearend out with it. I've broken tail shaft housings off the tranny from shoving the driveshaft forward when it breaks. Don't fool around with those stock shafts.
And yes your pinion angle sounds in the ballpark. Anywhere from -1 to -4 degrees is acceptable for a street/strip car.
10-19-2010, 07:58 PM #6
problem cured... pinon angles perfect stock driveshafts just couldnt take acttually hooking lol sphon top gun driveshaft ftw!
11-13-2010, 10:36 PM #7Member
- Oct 2009
- Philadelphia
Sunset metallic orange- '01 Camaro SS
That's what I'm afraid of happening to mine after the stage 2 tranny setup and 9" 40spline axles
Sent from my iPhone using Tapatalk
The sound of your piss hitting the urinal.......yea it sounds feminine!
11-14-2010, 02:25 PM #8
tunnel mount torque arm noise reduction ideas?
By shady milkman in forum Suspension and HandlingReplies: 8Last Post: 02-24-2017, 03:31 AM -
For Sale: umi tunnel mount torque arm brace and on car adj torque arm
By 99yellowz28 in forum Parts For Sale / TradeReplies: 3Last Post: 07-10-2011, 08:33 AM -
UMI Torque Arm Mount (Tunnel Mount)
By Z28boy2000 in forum Parts For Sale / TradeReplies: 2Last Post: 01-15-2011, 03:28 PM -
Need to know correct degree angle on rearend.
By Street Fighter in forum Suspension and HandlingReplies: 15Last Post: 01-23-2009, 02:57 AM
