    Bullet Boy Same ol Situation's Avatar
    Dec 2008
    Cincinnati, Ohio
    2002 CETA m6
    Akward squeak noise
    I recently installed the SLP LM1 on my car about 2 weeks ago. Recently I have been hearing a strange squeaking noise that sounds like its coming from the back. The whole set up is clamped on so could that be case?? Should I have it welded?? all feedback is much appreciated.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    On the SLP LM the exhaust comes VERY close to the upper pan hard bar support where the exhaust goes over the axle.
    My bet is that your exhaust is rubbing in this area.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Your best bet is to try and creat the noise while being outside the car, Ie wiggle the exhaust, start the car, move the body up and down etc etc. I wouldnt have the set up welded, clamps do the trick without noise and leaks as long as they are good and tight, double check all your clamps. Personaly i have seen a few that squeaked outback and a little lithium grease on the pivots points did the trick..
    J
    +1. Had the same problem with our Magnaflow catback. I ended up sliding the mid-pipe off the merge at the back of the Y around 1/4" and that provided sufficient clearance over the panhard brace.
    Dec 2008
    Cincinnati, Ohio
    2002 CETA m6
    Sooo what should i do go and grease the clamps and make sure there tightened well??
    Bragg NC
    Met. Sunset Orange
    01 SS
    No, No, No, dont grease the clamps, just ensure they are good and tight, i was talking about the suspensioin as far as grease...
    J
    Junior Member DrTrash's Avatar
    Aug 2010
    Phoenix
    2000 Pontiac Trans Am
    Put some more rubber in the bushing that holds the exhaust, this will lift the exhaust a centimeter, thus reducing the stupud noise.
  1. Akward moment of the year.
    By SouthernBornThriller in forum Almost Anything Goes
    Last Post: 12-20-2009, 08:10 PM
  2. wow akward situation
    By knightryda01 in forum Almost Anything Goes
    Last Post: 11-03-2009, 02:54 PM
  3. T-Top Squeak/Rubbing Noise
    By regerror6 in forum Firebird / WS6
    Last Post: 09-21-2008, 04:57 AM
  4. bad squeak what could it be?
    By bgable in forum Suspension and Handling
    Last Post: 12-02-2007, 06:12 PM
  5. Akward Pics of Kids you know...
    By SSwt00SS in forum Almost Anything Goes
    Last Post: 05-08-2007, 11:57 PM
