Results 1 to 20 of 23
Thread: Wet Carpet
    Member BirdCountry02's Avatar
    Feb 2008
    Virginia
    Maple Red Metallic
    2002 Trans Am M6
    Wet Carpet
    Hey guys, I need some help.I hope this is in the right section, but I have soaking wet carpet on just the driver side and I don't know where it came from. I'm gonna look into it, but what I really need help on is the floor pan. I ripped up some of the carpet and I found rust underneath. I know to sand it down, but what would be best to cover it so it doesn't rust up again? Someone mentioned undercoating the floorpan on the driverside, but i'm new to it so i'm not sure. Plus it'll be a while before I can afford new carpet, maybe I could just undercoat it instead of carpet. So do you guys think doing that would work? Or is there something else that'd be better that I could do?
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    You could grind off the rust and spray some primer over it to keep it from re rusting.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    I forget what it is called but when I was helping my dad restore a 71 spitfire we used this stuff that you sprayed on the rust and it got rid of it as long as it's not rusted through and we also use bondo and then had everything painted over.
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    I'd be a little more concerned on where the water is coming from? sounds like it might be a heater core leaking and running down to your driver side floor.
    Feb 2008
    Virginia
    Maple Red Metallic
    2002 Trans Am M6
    Quote Originally Posted by 1998 T/A View Post
    Don't get me wrong, I am concerned about the water getting in. Especially since I haven't seen any water leaking in, but I HATE rust. When I saw it I flipped. So right now I was just seein what's the best option for taking care of it, if just sanding and priming it's best or if something else is better. Thanks for that scenario though, i'm gonna look into that ASAP. You know how to find out if it is that, or how to stop it?
    Pittsburgh
    2008 Hummer H3
    T-top maybe leaking..
    Senior Member JoshuaGrooms83's Avatar
    Lake Geneva, WI
    98 Trans Am
    You know ive been having the same issue actually latly. I visit a carwash that is actually apart of my work so i use it on a weekly basis . im wonding if the highpressure wash forces water in somewhere. either on top or undernieth. not sure. I shampoo vacuumed it (also at my work lol) and sucked up all the water and cleaned my carpets very well in the process. i gotta pull up the carpet and see if anything is on the body. this is a recent development. I cant stand all the water in my car!!!
    Feb 2008
    Virginia
    Maple Red Metallic
    2002 Trans Am M6
    I thought this... but when it rains, I don't see any water come through the top. I'm gonna have someone spray water til I find it, can't stop it without finding the issue first
    Quote Originally Posted by JoshuaGrooms83 View Post
    Annoying, isn't it? My carpet needs completely removed, but then again it was in bad shape anyways
    Junior Member BlackBirdWS.6's Avatar
    Sep 2010
    Austintown, Oh
    Custom GM White
    86 Fiero GT
    Evapo-rust can get the rust off if you don't want to sand/grind etc but did you smell it? I know it sounds wierd but if it doesn't smell like water then maybe it wouldn't be from underneath your carpet. But how rusty is it?
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    To stop the heater core from leaking you have to put a clamp on the hose going into the firewall...have you noticed any low levels of fluid in your radiator or reserve? that will tell you if it is leaking or not.
    Sep 2010
    Austintown, Oh
    Custom GM White
    86 Fiero GT
    if your heater core is leaking your car will stink tho cause when mine broke the interior smelled awful and if you would turn your defrost on itd shoot coolant on my windshield.
    Auto Painter RyanJM's Avatar
    Houston, TX
    Go to the auto parts store or most Walmarts have it. I forgot the exact name think it was in a blue can and it's a rust conversion coating. Sand it down and spray it on and it will look like black primer and if there is any small amount of rust it won't let is spread. I use to use this rust converter when I lived up north and paint would bubble you could never get all the rust in some pits off so you spray this on and then paint it and I never had any rust come back after in the area.
    Bit defiantly find the leak as well or it could create more problems later. As for the carpet just use some resolve shampoo for now and depend of.where you live either leave the windows down and air dry it or you can use a Blo dryer or heat gun to speed it up just be careful with a heat gun.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Feb 2008
    Virginia
    Maple Red Metallic
    2002 Trans Am M6
    Quote Originally Posted by BlackBirdWS.6 View Post
    No it doesn't smell, it's def water that caused it. I just removed the carpet and there was a TON of water. I mopped it up, but the carpets shot to hell. I'll just have to replace it later. The rust isn't too bad, just surface rust. I'm lucky I caught it now before it got really bad.
    Yeah I don't think they're lower, i'd check em now but it's too dark outside
    Yeah, i'm thinkin this isn't it. i'm gonna be scouring the car for water the next time it rains. I'm thinking its sneaking past me so I never noticed it
    Quote Originally Posted by RyanJM View Post
    Thanks man. I'll have to do this. Yeah, i'm on a mission to find where its coming from. I don't want to find water like this again, when I removed the carpet there was so much stading water
    now greybat66
    bloomfield nj
    1998 trans am
    thats one of your ttops its coming down your gasket , u might have a small tear.Also u can go to any auto parts, they sell a spray can that turns rust into primer .Good luck.
    now greybat66
    bloomfield nj
    1998 trans am
    Also my best friend had a similar problem but his car is a spyder eclipse and he found out that the water was coming from a hose attached to the ac .
    Sep 2010
    Austintown, Oh
    Custom GM White
    86 Fiero GT
    Quote Originally Posted by purplebat66 View Post
    it could be related to that but for it to leak i think you would have to have the a/c on because it takes the moisture out of the air. But i had a similar problem in my g5 because a drain plug wasn't drilled out so the heater core i believe would fill with water then leak from there and out of the vents and drench the interior
    Mar 2010
    St Pete, FL
    Bat mobile black
    i have some kind of liquid material i found on the carpet, it seems old but i never noticed it before. Oh ya and it also seems like oil.
    Pony_eater Pony_Eater's Avatar
    Aug 2008
    Murrieta, Ca
    2000 trans am ws6
    hey post a picture so i can see what amount of rust youre dealing with but SEM makes a great product called rust mort...also POR-15 is a good one to but take a pic so i can see what to suggest to you
    Winnipeg
    I had a similar problem in my C5 but the water was in the passenger side and what it ended up being was water not being able to drain for the A/C. There is a rubber tube for the drain with a slit and it was plugged so with the A/C being on for long periods the water could not drain out filled up and drained inside the car.
    The drain had leaves and pine needles and crap in there. Snipped the bottom of the tubes and everything was fine after, the cowl even had a couple of drains so it may be worth checking on an F-body also.
    Marylandistan
    2001 Trans Am (sold)
    I'll second the POR 15.
  1. Anyone buy new carpet for their car?
    By mezzoni in forum Appearance Section
    Last Post: 05-13-2013, 11:00 AM
  2. Question: OEM Carpet
    By RichR in forum Firebird / WS6
    Last Post: 02-01-2011, 11:52 AM
  3. carpet wet?
    By jrea42 in forum Camaro / SS
    Last Post: 12-06-2008, 07:36 AM
  4. wtb carpet
    By faust in forum Parts Wanted / Trade
    Last Post: 01-28-2007, 04:37 PM
  5. My AC leaks onto my carpet!!
    By GottaHaveLS1 in forum General Help
    Last Post: 08-11-2006, 01:43 PM
