Thread: Steering column
    Aug 2010
    NEW ALBANY
    2002 ws6 ta convertible
    Steering column
    How hard is it in these cars to change the steering column my tilt is messed up if put enough pressure on it it will fall down sounding like a stripped gear!!!
    Sent from my Droid using Tapatalk
    TRUE DUALS
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Does it move up and down if you hold the wheel? Unless something is broken internally it can be fixed. You must completely disassemble the column. There is 2 or three bolts that can loosen over time. Tighten with some loctite and it will be good.
    Aug 2010
    NEW ALBANY
    If grab the top of the wheel and pull back the whole column falls down
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    The column is a breeze to change out- done it a couple times on mine.
    1. Take the lower dash panel off (four screws), unplug the trunk release button.
    2. Loosen bolts at the floor where the plate meets floor (three or four 13mm bolts- I think).
    4. Remove bracket under the column. (Two 10mm nuts).
    5. Remove two 13mm nuts that hold the column up to the dash.
    6. Remove the bolt that holds the column to the knuckle.
    7. Unplug all the electrical.
    8. Yank it out.
    Yep. It's that easy. And yes, I've done this a couple of times.
    Now, if the tilt has play in it, it is because of the bolts at the tilt mechanism have backed out. This is a problem that GM tilt columns have had for eternity- my 71 Chevelle did the same thing. You have to pull the column apart, and then there's a special tool you use to take the pins out from the tilt so you can get to the bolts.
    2000 Pontiac Firehawk #0041 of 742
  1. 02' steering column
    By johnfin in forum Firebird / WS6
    Last Post: 08-17-2012, 06:15 PM
  2. Steering Column
    By Fterr99ss in forum Camaro / SS
    Last Post: 10-07-2010, 04:01 AM
  3. 97 GMC Steering column
    By 1998 T/A in forum Parts Wanted / Trade
    Last Post: 04-24-2010, 08:48 AM
  4. Will this steering column fit
    By shanepatrick1230 in forum Firebird / WS6
    Last Post: 09-15-2008, 05:23 AM
  5. Need steering column
    By los41682 in forum Parts Wanted / Trade
    Last Post: 06-13-2006, 07:33 PM
