Results 1 to 20 of 141
Thread: LS6 valley cover in pics
10-03-2010, 08:45 PM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
I got the valley cover to eliminate the crappy stock PCV setup.....little did I know how crappy it was and how urgently I needed to get this done....my idle has always been a bit wonky.....everything I would do and could do to make it better helped......plugs.....wires......fuel filter etc........etc......did help....but it was never THE solution......lately my idle has gone off the the deep wonky end......and it was never the same.....idle good for 1 min.....shake like a wino needing a bottle the next......and visa versa
I could not help but think vacuum leak....but where? I got the valley cover and have put off the install for awhile .....finally got around to it.....and just as I suspected the stock PCV had completely crapped out.....and I know if mine did ......and unless you changed yours out........yours has too....this damm rubber is 10 yrs old people.....its mush.....change it out or get a LS6 cover....you will thank me later.....I used the write up on LS1 how to . com as a guide.......but it fell waaaaay short in some areas.....follow along
10-03-2010, 08:46 PM #2Senior Member
- Jan 2010
- texas
the part number for the NEW style coverLast edited by sjsingle1; 10-04-2010 at 07:30 AM.
10-03-2010, 08:47 PM #3Senior Member
- Jan 2010
- texas
10-03-2010, 08:47 PM #4Senior Member
- Jan 2010
- texas
10-03-2010, 08:48 PM #5Senior Member
- Jan 2010
- texas
step 1.............remove TB
10-03-2010, 08:49 PM #6Senior Member
- Jan 2010
- texas
vacuum leak number 1.......that ground strap in there acted like a razor bladeLast edited by sjsingle1; 10-04-2010 at 07:04 AM.
10-03-2010, 08:49 PM #7Senior Member
- Jan 2010
- texas
10-03-2010, 08:50 PM #8Senior Member
- Jan 2010
- texas
vacuum leak number 2......the back junction was split in halfLast edited by sjsingle1; 10-04-2010 at 07:04 AM.
10-03-2010, 08:50 PM #9Senior Member
- Jan 2010
- texas
10-03-2010, 08:51 PM #10Senior Member
- Jan 2010
- texas
10-03-2010, 08:52 PM #11Senior Member
- Jan 2010
- texas
dis connecting the wiring was a PITA
10-03-2010, 08:53 PM #12Senior Member
- Jan 2010
- texas
10-03-2010, 08:55 PM #13Senior Member
- Jan 2010
- texas
the back 2 bolts on both sides of the intake were a ROYAL PITA ........the tranny tube was in the way on the last bolt and I had to bend it out of the way to reach it
10-03-2010, 08:56 PM #14Senior Member
- Jan 2010
- texas
the valley was a freakin mess......and I try my hardest to keep my engine clean.....and dispite my trying hard not to.......I broke the OPSU
10-03-2010, 08:58 PM #15Senior Member
- Jan 2010
- texas
10-03-2010, 08:58 PM #16Senior Member
- Jan 2010
- texas
cleaning up the mess in here took me 2 hoursLast edited by sjsingle1; 10-03-2010 at 09:31 PM.
10-03-2010, 08:58 PM #17Senior Member
- Jan 2010
- texas
it broke......the OPSU
..........the valley cover bolt by the OPSU was so loose I could take it off by hand...... vacuum leak number 3 and OIL leak
10-03-2010, 09:00 PM #18Senior Member
- Jan 2010
- texas
the vacuum hard line in the lower T is the 1 for the AIR.....the line was removed and the nipple was cappedLast edited by sjsingle1; 10-04-2010 at 07:03 AM.
10-03-2010, 09:01 PM #19Senior Member
- Jan 2010
- texas
wish I had a LS6 intake to put on
10-03-2010, 09:01 PM #20Senior Member
- Jan 2010
- texas
so thats whats inside a OPSU
LS2 Valley Cover
By PitchBlackLS2 in forum LS2/LS3/LS4/LSxReplies: 0Last Post: 11-28-2016, 06:49 AM -
Question: ls6 valley cover
By tangkiller_z28 in forum General HelpReplies: 7Last Post: 07-13-2011, 12:05 PM -
Valley cover
By sutie in forum Firebird / WS6Replies: 5Last Post: 02-24-2011, 05:07 AM -
LS6 Valley Cover and Catch Can
By ls1camino in forum External EngineReplies: 11Last Post: 05-20-2009, 08:23 AM -
LS! Valley Cover
By parbreak in forum Parts For Sale / TradeReplies: 0Last Post: 04-22-2006, 06:26 PM
