Results 1 to 3 of 3
    LOWANDSLOW
    Guest
    How much can I spray if...
    I currently have a 100 shot dry. I am curious to know how much i could spray if i upgraded to 30lb injectors and a 255 intank? My car is a 2000 Z28 M6 w/ lid, exhaust.
    Local Bum TARZAN's Avatar
    Memphis Area
    Cobra, Z28, GN, F250
    Personally, I would advise you taking the $$$$ on injectors and converting it to a wet kit. Then, you would have no problems spraying 150+ shot....
    As for the pump, I'd advise a Racetronix kit, wiring and all. Most efficient for a "normal" car lol
    -Will
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    don't forget, when upgrading injectors, you have to reprogram the PCM for them as well. if you do not, it will run richer than normal.
  1. Question: How much spray should i run?
    By Sarge91 in forum Nitrous
    Last Post: 09-29-2009, 11:22 PM
  2. Question: How Much To Spray...
    By MikeSomething in forum Nitrous
    Last Post: 06-03-2008, 01:36 PM
  3. Would you spray?
    By RealLiveMD in forum Nitrous
    Last Post: 04-27-2008, 09:21 PM
  4. looking for spray
    By egod in forum Nitrous
    Last Post: 04-14-2008, 11:58 AM
  5. 4.3L Okay for Spray?
    By blackhawk01 in forum Nitrous
    Last Post: 05-04-2007, 05:18 PM
