    Internet Tough Guy Fury_786's Avatar
    Oregon
    Sinister, SixGun
    2001 SS, 2002 L36 M5
    200 shot or not?
    my buddy has a stock 06 gto...yes i know this is the ls1 forum, but ls2 is gay
    anyhow, he ran 11.6 @ 118 on a 100 shot, and we were thinking about doing it big or something with a 200 shot.
    aside from breaking drivetrain and whatnot, will the stock rail flow enough fuel for this or no?
    Impounded chknhwk01's Avatar
    n/e philly
    2001t/a ws6 firdbrid
    Talking buk buk buk,,,,,,,,,, sinba.............
    you may have to change your injectors, and you need a nother fuel pump
    255 pump... but a 150 is all you need, for that car...
    chknhwk buk buk buk.....
    Oregon
    Sinister, SixGun
    there isnt a need to change injectors with a wet shot?
    Member LSXZ28's Avatar
    Aug 2009
    On the dyno tuning in MD
    99 Silverado
    You don't need injectors... but you will need a fuel pump...
    150 is all I would recommend on a stock bottom end unless you REALLY know what you are doing... with 200, the tune better be dead right, or you will break parts!
    GM EFI Tuner
    2002 Trans Am WS6 - 9.41@143mph, #3675, on pump gas and drag radials - sold
    Oregon
    Sinister, SixGun
    got it, we were thinking about doing it just once or twice to see
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    Member 94 Formula's Avatar
    La Mesa
    M3 SMG 350HP
    Car should run a 10.99 on a 150wet if you spray out of the hole with a 1.5 60ft.. I would not do a 200 on a stock motor unless it is tuned for it.
    DW
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i've been as high as 250 when i had my completely stock motor right down to the LS1 intake and stock exhaust manifolds with a walbro in tank 255 LPH pump. fell over in the 1/8 mile. this was a dual setup 100/150. so i jetting a single stage to 200 and did fine.
  1. Question: 150-200 shot
    By Blackbird WS6 in forum Nitrous
    Last Post: 12-20-2010, 05:49 AM
  2. 01 Z28 Zex 150 Shot
    By karpetcm in forum Nitrous
    Last Post: 10-13-2010, 04:52 PM
  3. 150 shot
    By ssweet99ss in forum Nitrous
    Last Post: 05-24-2008, 07:14 PM
  4. 125 Wet Shot
    By johuckabee in forum Drag Racing
    Last Post: 04-30-2006, 04:04 PM
  5. Dry shot on a TPI car
    By En Fuego in forum Nitrous
    Last Post: 09-08-2005, 03:52 PM
