Results 1 to 10 of 10
Thread: Factory CD Changer mounting
03-09-2006, 08:38 PM #1Junior Member
- Dec 2005
- Missouri
Silver---Black- 1969 Z28, 1999 T/A WS6
I found a factory 12-disc cd changer that plugs into the existing harness on my factory monsoon cd radio system and it works great. Now all I need is to mount it. I know about where it goes in the back. I ordered 3 brackets from GM. Does anyone have any pictures? My car is a 99 Ws6 convertible if that makes any difference.
thanks
03-10-2006, 03:41 AM #2Junior Member
- Dec 2005
- Bowman, SC
Crytal Red Tint Coat- 2013 SS Camaro Covertible
It goes in the space behind the drivers side rear wheel well, facing the right side I took mine out and put in a Kenwood system. I mounted the Kenwood changer in the same location, but i had to drill a couple of new holes. I don't think the holes come predrilled. You will have mark them and drill them out.
Originally Posted by markyf
I don't have any picks of the changer, but I can take some if you need a look.2013 Camaro SS Convertible, Whipple Supercharger, Kooks Coated 1 7/8" headers, CAI Cold air induction
http://s33.photobucket.com/user/Deea...?sort=3&page=1
03-10-2006, 03:59 AM #3Member
- Jan 2006
- NY
yellow- 02 Collector Edition TA
I basically ordered every bracket i found in the GM parts book. It pinches the CD changer brackets under the carpet, there are no holes to mount it. My carpet had two spots where it was perforated/slit the brackets slipped through those two spots and then bolted to the changer.
03-10-2006, 04:02 AM #4
sorry just took mine out
03-10-2006, 04:10 AM #5Junior Member
- Dec 2005
- Bowman, SC
I only drilled two holes for my kenwood, cause the factory brackets woul not work. I also put a 1" thick peace of foam underneath the unit so that bumps would not jar it!
03-10-2006, 08:29 AM #6Junior Member
- Dec 2005
- Missouri
Thanks for the info so far, guys. If somebody has a picture of how the brackets are mounted to the trunk floor, it would help me.
03-15-2006, 08:50 PM #7Junior Member
- Mar 2006
- Brighton, MI
Black- 2002 Camaro Z28
I also installed a factory CD changer in my car. The factory apparently installed the two long brackets by spot welding them to the floor. I used the factory brackets and held them down with two screws in each
03-15-2006, 09:20 PM #8Junior Member
- Mar 2006
- Brighton, MI
May help...
Here's a picture of the CD changer with brackets before mounting.
CD Changer
And a really bad exploded view.
Exploded View
03-16-2006, 10:15 AM #9Junior Member
- Dec 2005
- Missouri
Thanks ZeeVert. That's the kind of help I was looking for. If I could see a picture of the exact factory mounted bracket, it would be perfect. I'm going to look for a local car that has a factory system. I bought the factory brackets and I will glue or screw them down. I didn't realize they were originally spot welded.
03-16-2006, 04:02 PM #10Junior Member
- Mar 2006
- Brighton, MI
I'm not positive... I never saw a factory install, but what else could it be? The pictures do show the factory brackets that I ordered from GMDirect. They were only a few bucks each. They weren't painted, so I painted them pretty thick with black to keep them from rusting.
Factory CD Changer
By Siciliano15 in forum Parts Wanted / TradeReplies: 1Last Post: 11-06-2008, 07:19 PM -
For Sale: Factory 12-Disc CD-Changer Cartridge.
By 98CamaroSS in forum Parts For Sale / TradeReplies: 2Last Post: 04-05-2008, 08:10 PM -
Looking for a factory CD changer.
By jigger1166 in forum Stereo and ElectronicsReplies: 1Last Post: 04-27-2007, 11:56 AM -
installing a factory cd disc changer
By redss2000 in forum Stereo and ElectronicsReplies: 5Last Post: 06-27-2006, 02:36 PM -
Factory CD Changer
By proroc in forum Stereo and ElectronicsReplies: 11Last Post: 06-26-2006, 11:02 AM
