Results 1 to 14 of 14
    Member SmokinSS's Avatar
    Lanc. PA
    RED
    1998 Camaro SS Vert
    fuel filter on a 2004 Silverado 2500hd?
    Hey does anyone know if the fuel filter on a 2004 Chevy Silverado 2500hd with a 6.0 gas engine is in the tank or is it inline? I'm guessing it's in the tank, because I can't seem to find one. But thought I'd ask because it seemed weird to me since all my other trucks were inline. If it is in the tank does it need to be changed? Thanks!
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    2004 6.0 trucks have the filter in the tank. Its part of the fuel pump and sending unit assembly.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by cpop98ws6 View Post
    Yes.
    You basically change the fuel filter when the fuel pump takes a crap.
    2018 Tahoe - Silver - OEM
    Aug 2000
    Indy
    Great, is it the same for a 2007 2500HD ?
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    Aug 2000
    Indy
    Does anyone have a write up on dropping the tank on a 2007 2500HD ?
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by Danger731 View Post
    From GM:
    Fuel Filter
    The fuel filter is contained in the fuel sender assembly inside the fuel tank. The paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Relieve the fuel system pressure. Refer to Fuel Pressure Relief.
    Drain the fuel tank. Refer to Fuel Tank Draining.
    Remove the fuel tank fill pipe. Refer to Fuel Tank Filler Pipe Replacement.
    Disconnect the fuel tank fuel feed (1) and EVAP (2) line quick connect fittings from the chassis lines. Refer to Plastic Collar Quick Connect Fitting Service.
    Cap the fuel and EVAP lines in order to prevent possible system contamination.
    Remove the EVAP canister vent solenoid pipe clip (1) from the frame crossmember.
    Disconnect the EVAP canister pipe quick connect fitting (2) from the fuel tank EVAP pipe. Refer to Plastic Collar Quick Connect Fitting Service.
    Disconnect the EVAP canister vent solenoid pipe quick connect fitting (3) from the EVAP canister. Refer to Plastic Collar Quick Connect Fitting Service.
    Disconnect the chassis wiring harness electrical connector from the EVAP canister vent solenoid.
    Remove the chassis wiring harness clip from the fuel tank shield.
    Insert a small flat bladed tool between the EVAP canister vent solenoid and the fuel tank bracket, disengaging the retainer (1).
    Slide the EVAP canister vent solenoid off the bracket towards the passenger side of the vehicle.
    Position and secure the EVAP canister vent solenoid out of the way.
    Place a suitable adjustable jack under the fuel tank.
    Remove the fuel tank strap bolts.
    Remove the fuel tank straps.
    Important: When lowering the tank, ensure that the fill neck on the tank does not get hung up on the chassis wiring harness.
    Lower the fuel tank half way.
    Disconnect the chassis wiring harness clip at the frame crossmember.
    Lower the fuel tank until the electrical connections are accessible.
    Disconnect the chassis wiring harness electrical connector from the fuel tank pressure sensor.
    Disconnect the chassis wiring harness electrical connector from the fuel tank module.
    Completely lower the fuel tank.
    With the aid of an assistant, place the fuel tank in a suitable work area.
    If replacing the fuel tank proceed to the next step, otherwise proceed to step 10 in the installation procedure.
    Remove the fuel tank shield push on retainers.
    Remove the fuel tank shield.
    Disconnect the fuel feed pipe quick connect fitting from the fuel tank module. Refer to Plastic Collar Quick Connect Fitting Service.
    Remove the fuel feed pipe from the fuel tank clip (1).
    Remove the EVAP canister purge pipe from the fuel tank clip (1).
    Disconnect the EVAP rear pipe quick connect fittings from the rollover valve and the fuel tank module. Refer to Plastic Collar Quick Connect Fitting Service.
    Remove the EVAP rear pipe from the fuel tank clips (1 and 2).
    Disconnect the small EVAP rear pipe quick connect fittings from the rollover valve and the fuel tank module. Refer to Plastic Collar Quick Connect Fitting Service.
    Remove the fuel tank module. Refer to Fuel Tank Fuel Pump Module Replacement.
    Installation Procedure
    Install the fuel tank module. Refer to Fuel Tank Fuel Pump Module Replacement.
    Position and connect the small EVAP rear pipe quick connect fittings to the rollover valve and the fuel tank module. Refer to Plastic Collar Quick Connect Fitting Service.
    Position and connect the EVAP rear pipe quick connect fittings to the rollover valve and the fuel tank module. Refer to Plastic Collar Quick Connect Fitting Service.
    Install the EVAP rear pipe to the fuel tank clips (1 and 2).
    Install the EVAP canister purge pipe to the fuel tank clip (1).
    Position and connect the fuel feed pipe quick connect fitting to the fuel tank module. Refer to Plastic Collar Quick Connect Fitting Service.
    Install the fuel feed pipe to the fuel tank clip (1).
    Position and install the fuel tank shield.
    Install the fuel tank shield push on retainers.
    With the aid of an assistant, place the fuel tank in a the adjustable jack.
    Raise the fuel tank until the electrical connections can be made.
    Connect the chassis wiring harness electrical connector to the fuel tank module.
    Connect the chassis wiring harness electrical connector from the fuel pressure sensor.
    Completely raise the fuel tank into position.
    Notice: Refer to Fastener Notice in the Preface section.
    Install the fuel tank straps.
    Install the fuel tank strap bolts.
    Tighten
    Tighten the bolts to 40 N·m (30 lb ft).
    Remove the adjustable jack from under the fuel tank.
    Unsecure and position the EVAP canister vent solenoid to the fuel tank.
    Slide the EVAP canister vent solenoid onto the bracket towards the driver side of the vehicle.
    Ensure that the EVAP canister vent solenoid engages the fuel tank bracket retainer (1).
    Connect the EVAP canister vent solenoid pipe quick connect fitting (3) to the EVAP canister. Refer to Plastic Collar Quick Connect Fitting Service.
    Connect the EVAP canister pipe quick connect fitting (2) to the fuel tank EVAP pipe. Refer to Plastic Collar Quick Connect Fitting Service.
    Install the EVAP canister vent solenoid pipe clip (1) to the frame crossmember.
    Connect the chassis wiring harness electrical connector to the EVAP canister vent solenoid.
    Install the chassis wiring harness clip to the fuel tank shield.
    Remove the caps from the fuel and EVAP lines.
    Connect the fuel tank fuel feed (1) and EVAP (2) line quick connect fittings to the chassis lines. Refer to Plastic Collar Quick Connect Fitting Service.
    Install the fuel tank fill pipe. Refer to Fuel Tank Filler Pipe Replacement.
    Refill the fuel tank.
    Install the fuel cap.
    Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection.
    Perform the following procedure in order to inspect for leaks:
    32.1. Turn the ignition ON, with the engine OFF, for 2 seconds.
    32.2. Turn the ignition OFF for 10 seconds.
    32.3. Turn the ignition ON, with the engine OFF.
    32.4. Inspect for fuel leaks.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Here are the crappy pictures that go with the write up.
    USA
    Velocity Yellow
    2008 Corvette Z06
    USA
    Velocity Yellow
    2008 Corvette Z06
    And then do everything in reverse to install.
    Aug 2000
    Indy
    Damn, I see. pita
    should just raise the bed !, eight bolts !
    USA
    Velocity Yellow
    2008 Corvette Z06
    Damn, I see. pita
    Raising the bed is a trick of the trade. It is easier to do as long as you have some buddies to help you get it off the frame and safely out of the way so it won't come crashing down on you.
    Are you doing this to swap the fuel filter? Because I know GM doesn't make a replacement, you have to buy the whole fuel module.
    Aug 2000
    Indy
    done, took out the four bolts on the driver side, loosened the 4 passenger side bolts and jacked it up tol acess the gas tank. All gas is out, gunna drop in some dry-gas add 2 gall of 91 and see if she will turn over.
    Aug 2000
    Indy
    Can't believe how much crap is attatched to the 2500 gas tank compared to my camaro
  1. kinked fuel line while changing fuel filter
    By krese in forum Firebird / WS6
    Last Post: 10-04-2010, 03:02 PM
  2. Question: Fuel filter on 2004 gto
    By 5.7literMustangEater in forum GTO
    Last Post: 12-02-2008, 02:41 AM
  3. Silverado In-line fuel filter
    By Nastyfoot in forum GM Trucks
    Last Post: 10-12-2008, 11:35 PM
  4. 2004 Chevy 2500HD exhaust upgrades
    By thearborbarber in forum GM Trucks
    Last Post: 07-15-2008, 07:59 PM
  5. 2004 Joe Gibbs Supercharged Silverado
    By Kidreynolds in forum Vehicles For Sale / Trade
    Last Post: 03-29-2006, 04:19 PM
