Results 1 to 2 of 2
09-22-2010, 02:55 PM #1
- Oct 2005
- baltimore md
black- 99 ws6
what do you think of this cam package
I have a 99 ws6 6spd just have bolt ons i was wondering how this set up would worl with a pretty much stock motor and down the road spraying a 150 shot on it, thanks
54-428-11 Cam Shaft,,,, Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,200-7,400
Intake Duration at 050 inch Lift 228
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 228 int./230 exh.
Advertised Intake Duration 281
Advertised Exhaust Duration 283
Advertised Duration 281 int./283 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.571 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.573 in.
Valve Lift with Factory Rocker Arm Ratio 0.571 int./0.573 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Grind Number XR281HR
26918-16 Valve Springs
772-16 Retainers
7955-16 Push Rods
875-16 Roller Lifters
1375-16 Pro Magnum RockersLast edited by onebadassws6; 09-22-2010 at 05:03 PM.
09-26-2010, 08:02 AM #2
thats the cam i run
its a little bit big for stock heads......if ur looking to change them they go with it if ur going to stick with stock heads its going to be too high of an rpm range then ull need
i swaped from a gmpp hot cam and to this one and 1/4 times slowed down a little bit.. mph picked up .5 and its not as much fun to drive on the street
it come in hard at 5500 and is gone @6400
I got a package.
By Heartbreak1 in forum Rocky Mountain MembersReplies: 11Last Post: 08-14-2007, 12:10 PM -
W68 Package
By BanditTransAm in forum Firebird / WS6Replies: 20Last Post: 03-03-2007, 03:16 PM -
any one have the 383 package from lpe?
By jbb6811 in forum Internal EngineReplies: 5Last Post: 10-30-2006, 12:43 PM -
ram air w/ws6 package
By bird flew in forum Firebird / WS6Replies: 7Last Post: 03-04-2006, 05:52 PM -
SLP package
By 00ls1bird in forum External EngineReplies: 4Last Post: 02-15-2006, 10:22 AM
