Results 1 to 1 of 1
09-21-2010, 03:10 PM #1
- Aug 1999
- No Where
2010 Camaro Toe Rods and GM 200-4R Transmission Pan - Test A
2010 Camaro Toe Rods and GM 200-4R Transmission Pan - Test And Tune
BMR has developed an upgrade over the factory stamped-steel toe rods in the fifth-gen Camaro. What are toe rods? They keep the wheels in the Camaro's independent rear suspension pointed straight.Vacuum And Turbo Hose Quick-Coupler System
Oomph Labs
435/425-2222
OomphLabs.com
Oomph's unique system converts all vacuum and turbo hoses to a quick-coupled setup, eliminating broken fittings or barbs during removal or troubles with rigid hose ends. They connect and disconnect in half a twist of your finger and thumb, are capable of withstanding high underhood temperatures, and are rated for 30 inches of vacuum and 135 psi of pressure. Color-coded lines and fittings can be formed in dozens of different configurations. And with a quick-coupled tee in place, hooking up a vacuum or pressure gauge is easy. The fittings consist of aluminum rotating collars that snap onto molded nylon male hose ends. These, in turn, connect to nylon female-flanged hose ends. The rotating collars are available in a variety of colors, and the hose-end connectors accept most common hose sizes.
Price: $59.00 (one car)
Price: $99.00 (multicar)
Photo Gallery: 2010 Camaro Toe Rods and GM 200-4R Transmission Pan - Hot Rod Magazine
2010 Camaro Toe Rods and GM 200-4R Transmission Pan - Test And Tune | Digg It | Add to del.icio.us
More...
First Test: 2010 Chevrolet Camaro
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 06-17-2009, 10:10 PM -
MT 2010 Camaro test video
By gjb in forum Camaro / SSReplies: 1Last Post: 04-08-2009, 07:26 PM -
By gjb in forum Almost Anything GoesReplies: 5Last Post: 04-08-2009, 08:55 AM -
2010 SS Camaro Road Test
By karpetcm in forum Camaro / SSReplies: 106Last Post: 03-31-2009, 07:42 PM -
new 2010 Camaro SS spied in AZ outside test site
By terps in forum Camaro / SSReplies: 39Last Post: 03-24-2008, 10:35 AM
