Results 1 to 20 of 46
Thread: Spark PLugs and Wires
09-19-2010, 02:33 PM #1Last of the Breed
- Sep 2010
- Farmington Hills, MI
Navy Blue Metallic- 2002 Trans Am WS6 NBM
What does everybody out there think about AC Delco Iridium plugs and MSD wires?
09-19-2010, 02:42 PM #2
That works.
09-19-2010, 02:45 PM #3
I've used them in everything for quite a few years now.. Never had any issues.. However you'll get other oppinions on the subject..
09-19-2010, 07:18 PM #4Senior Member
- Jan 2010
- texas
silver- 2000 formula
IRs are all i will use now
09-19-2010, 09:31 PM #5
I have the ngk tr-6 plugs and msd wires, really woke up my car plus the plugs were really bad in the car, didnt look like they had been changed in years since I bought the car last year in july. I havent had any problems from the set up that I have.
09-20-2010, 04:52 AM #6Last of the Breed
- Sep 2010
Wheren do I find the NGK TR6? I couldn't find them at Summit Racing for my T/A. I was trying to put together an order together with the Summit Racing salesman and he said that there were MSD wires for our car. He said there were 2 for the LS1. One was a spiral core and one was a copper core. The copper core were 59.95 and the spiral core was 128.95. The spiral core were said to be for the pontiac and chevy and the copper was for the chevy. Spiral core is supposed to be better, but do we have to have it for our pontiacs?
09-20-2010, 05:03 AM #7Last of the Breed
- Sep 2010
I started to take out my wires and plugs and I got the 4 on the drivers side no problem. The passenger side, a whole different story. I need to have the hands of a ten year old boy and the strength of a gorilla to get those out. Any help would be appreciated by me and my knuckles.
09-20-2010, 05:40 AM #8Junior Rocketeer
- Sep 2005
- Russiaville, Indiana, United S
Sunset Orange- 2001 Z28
http://www.installuniversity.com/ins...sity/index.htm
install university has a good write up with pictures even.
I printed it out and took it out there with me to the garage.
Even had blood stains on it after I was done.
Fun stuff.
I also used the iridium plugs with msd wires. no complaints
as for anything other than bodywork being different on pontiac vs chevy, it's BS they are both the same car under a different skin.
09-20-2010, 05:42 AM #9
I ordered my plugs through KY Speed. You can shoot a PM to Mark at "marksls1ta" to check availability.
09-20-2010, 10:42 AM #10
pm sent to you, on the package deal I got for my msd and ngk tr-6 plugs.
09-20-2010, 12:34 PM #11
I like the MSD wires. AC plugs are good quality, but I got away from them due to the fact they no longer offered various heat ranges for the application.
I use Autolite plugs in either APP form or AR's depending on what I'm doing.
09-20-2010, 07:10 PM #12Last of the Breed
- Sep 2010
I was told by a parts guy that AC Delco and NGK are the same plug, made by the same manufacturer. Any body eard the same. Also I heard that the low resistance in the MSD wires causes radio interferance. Any body experience that? Also, I was told that the stock Delphi wires are the best for our car. I have no experience with any of this. I wanted to run what I have been hearing by forum, to see what your take is on this info. Thanks. I want to get this figured out so I can put them in.
09-20-2010, 07:12 PM #13Last of the Breed
- Sep 2010
jimmi7769. Thanks for the link.
09-20-2010, 11:01 PM #14215 heads,ms4cam,102 fast
- May 2009
- Lima,ohio
White- 2000 trans am
go ngk-55 plugs
09-20-2010, 11:23 PM #15Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Ac delcos are a good choice.,
I'm sure msd cables are a good choice too
I put on mine ac delco wires. Just garbage.
I bought some better cables go $45 and the delcos were $12500 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
09-21-2010, 02:08 AM #16
09-21-2010, 05:34 AM #17
It took 80,000+ miles to finally burn SOME of the electrode on ONE set of Iridiums.....Just sayin'....
09-21-2010, 08:08 AM #18
You've been misinformed. NGK's are a Japanese made plug and have nothing to do with ACDelco.
I stay away from the NGK's, we didn't like how they performed on the dyno. Didn't seem to matter what heat range we went with, we couldn't get a variation in EGR's, they all performed like a hot plug, so they were thrown in the trash. They can send those things back over seas where they came from as far as I'm concerned.
ACDelco plugs are good quality, but they have swapped around part numbers, some popular numbers aren't even available anymore, and in the process they stopped offering various heat ranges, so I stopped using them as well.
On the wires, I run MSD wires on several cars and have never had any type of radio interfearance.
09-22-2010, 03:38 AM #19Last of the Breed
- Sep 2010
I thought it was odd, about the radio frequency thing. Do MSD wires over stock make much of a difference, Any recorded difference? The stock Delphi wires are supposed to be good. I just got done switching all the plugs and wires. That passenger side was a chore. Removing the air pipe from the manifold, made all the difference in the world. It is funny that when your hand just fits where you need it, that every thing your arms rub against have to be sharp and pointy. If I had the hands of a 10 year old boy this would be so easy.
09-22-2010, 08:36 AM #20
Well I believe the MSD wires will have less resistance than the stock wires. Less resistance means more energy at the plug. That's the easiest way to explain it.
Measurable difference? An Ohm meter will show differences, whether the car actually performs better depends on how bad the stock wires were to begin with.
With these cars as old as they are now, if you were still running stock wires it's probably a good idea to swap them out anyway.
spark plugs and wires
By ASh302 in forum Internal EngineReplies: 40Last Post: 12-18-2014, 09:45 PM -
Question: Spark plugs wires
By 98maro in forum General HelpReplies: 5Last Post: 03-06-2010, 07:40 AM -
By bigboy T/A in forum Internal EngineReplies: 2Last Post: 07-09-2007, 04:18 PM -
Spark Plugs n Wires
By Evil Goat in forum GTOReplies: 13Last Post: 03-19-2007, 07:11 AM
