Results 1 to 3 of 3
Thread: Hey guys....... question????
09-16-2010, 08:35 PM #1
- May 2009
- Lima,ohio
White- 2000 trans am
where is the best place to put wideband bung to get best reading?????before or after o2 bung an should i put 2 in??????
09-17-2010, 01:47 AM #2
Mine is after the o2, only a few inches, but you want to get it as high as possible. If you were looking at the end of the pipe, try to get it at 2 o'clock.... 1 o'clock is better, but tough...
And, on the drivers side !
09-17-2010, 03:25 AM #3
Agreed. My Kooks LT's came with a spare bung for a wideband. Driver side just about an inch back from the other bung in the collector. You can see the spare bung in this pic:
As stated, you want to clock it with the tip of the sender pointing downward just a bit. This prevents moisture in the exhaust from accumulating and damaging the sensor. I think mine are almost parallel to the ground, just so they don't point upward you'll be fine.
Tax guys I have a question
By walterchang in forum Almost Anything GoesReplies: 10Last Post: 04-04-2010, 09:58 PM -
Serious Question Guys...
By Getzen_Guy in forum Almost Anything GoesReplies: 25Last Post: 06-04-2008, 02:16 PM -
Question for the Guys
By ls1blackbeauty98 in forum Almost Anything GoesReplies: 145Last Post: 04-19-2008, 07:03 PM -
QA1 guys have question
By 01WS6475hp in forum Suspension and HandlingReplies: 2Last Post: 05-28-2007, 06:19 PM -
hey guys So Cal Rim Question
By roadrashr6 in forum Wheels and TiresReplies: 3Last Post: 01-19-2006, 03:13 PM
