Thread: Cam positioning sensor
09-13-2010, 11:32 PM #1GET SOME
- Apr 2007
- San Antonio, Texas
Pewter Metallic- 2002 Pontiac Trans AM
Car has not been cranking on first and even sometimes second turn, very embarassing ..ive tried everything that i know of from checking fuel pressure which is good..relays good.. battery, alternator, new starter..new plugs, wires, fuel system cleaner..ive narrowed it down to the cam positioning sensor which a member brought to my attention..he said that the sensor can throw the ignition cycle off because it doesnt know what stroke the engine ended on therefore what to start it on..makes sense to me just dont know about where the sensor is located, where to buy(part #) and if it would matters if it has a cam swap(hot cam)..someone please enlighten me w/ your opinion..thanks
09-14-2010, 10:39 AM #2
Cam sensor is located right next to oil pressure switch behind the intake, ontop of the block.
Might e your crank position sensor too, it on the passenger side of the block above the starter
09-14-2010, 12:28 PM #3
Have you plugged a scanner into the OBDII port?
09-14-2010, 12:29 PM #4Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I vote crank positioning sensor
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
09-14-2010, 07:07 PM #5GET SOME
- Apr 2007
yea the cars been dynoed so im assuming thats why no codes pop up..plugged in w/ no light no codes came up as well..so leaning more towards cam positioning sensor or crank sensor??? symptoms kind of seem like both..it actually sounds like it doesnt know which stroke it is on when starting..
09-28-2010, 06:36 PM #6GET SOME
- Apr 2007
I replaced the crank positioning sensor this weekend didnt help at all..so its got to be the cam sensor?
10-08-2010, 03:34 AM #7
claytonr Did it fix your car the cam position sensor??? Im having same problem??
Question: Reading trans temp stock sensor vs aftermarket sensor in pan
By senicalj4579 in forum Computer & TuningReplies: 1Last Post: 03-29-2011, 07:41 AM -
xtra wide wheel positioning.
By bossho in forum DrivetrainReplies: 13Last Post: 10-05-2009, 10:03 AM -
Bottle positioning
By AfterYou in forum Firebird / WS6Replies: 6Last Post: 08-22-2009, 03:42 PM -
tweeter positioning
By bdavies11 in forum Stereo and ElectronicsReplies: 1Last Post: 02-09-2007, 12:27 AM
