Thread: Getting angry..
    Jun 2010
    Southern California
    Metallic Navy Blue
    1998 Camaro Z28
    Unhappy Getting angry..
    Hey there guys! Its been a little while since Ive been here, hopefully you can help! About a month ago my car died on the freeway and would crank but not start.. long story short, with some help from my father-in-law we found that there was a short (kept blowing the fuel pump fuse) and traced it to the pump itself.. I replaced the pump yesterday with an a/c delco pump too! and now the pump primes for 3 seconds like it should..and fuel is getting to the rails pretty good..but it just cranks and wont start up.. It is not blowing the fuse anymore.. and I am going to test the exact fuel pressure tomorrow, but any suggestions?!
    -Thanks!
    Chris
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Check the relays, specifically the ignition relay. I think you can swap it with the starter relay, not sure though.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Yes, I would assume the fuel problem is fixed and go after ignition. Pull a plug to check if it has fuel on it, check your spark.
    Someone had a similar problem and I think they found a bad crank position sensor. If everything else already suggested checks out it wouldn't hurt to look at that next.
    Sep 2010
    Montgomery, IL
    1999 Chevy Camaro Z28
    I just replaced my ignition relay under the hood. I found out that I was getting fuel to the injectors but did not have any injector pulse or spark. Try swapping that relay with another...I used a cooling fan relay. Hope that helps.
  1. So Would She be as Angry
    By GTP231 in forum Political / Debate Forum
    Last Post: 03-27-2014, 11:51 AM
  2. Very very angry indeed
    By cuervo25_1 in forum Political / Debate Forum
    Last Post: 03-26-2010, 07:19 PM
  3. The angry Australian...
    Last Post: 11-28-2009, 11:10 AM
  4. got a little angry in the gym yesterday
    By jaslivers in forum Almost Anything Goes
    Last Post: 11-03-2008, 06:39 AM
  5. More than a little angry....
    By Blk00ws6 in forum Southern Members
    Last Post: 10-26-2006, 04:46 AM
