    Car versus Truck
    As noted on here before... I don't know a whole lot about automatic transmissions. I believe our '07 Suburban also has a 4L60E in it. Is there any real difference in it as compared to the 4L60E in our T/A? I will be upgrading our car's transmission over the winter (hopefully) and am curious as to any differences. Since I will be using our truck to tow, if I happen to cook the transmission, would I have a spare?
    Gear ratios, output shaft, electronics, etc...
    Next... MrKid's Avatar
    Sep 2009
    Milford, CT
    '68 Camaro RS, '11 Camaro
    I assume the tahoe is 4 wheel drive? It probably has a differant tail and output shaft. I'm sure someone else will chime in here.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    The 4L60E is/was constantly evolving and I wouldn't be surprised if they weren't 100% compatible between 2002 and 2007. At one point I had a good grip on alot of the differences. I'd have to review my rebuild books to come up with an answer and if I get time tonite, I will.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    You would more than likley have to change the tail shaft, the internal elctrical, the shifter shaft, and the output shaft spline count and length may be different as well. The core would be the same. How ever gm went to a 5 or 6 speed auto at some point and it's not a 4l60e anymore. I have seen the mod numbers but I can't remember them right now. It might have been with the body change in 07 08.
  1. Question: truck computer versus car computer
    By BBCCarguy in forum Computer & Tuning
    Last Post: 11-03-2011, 08:47 AM
  2. 4th gen versus 3rd versus 2nd. ect.
    By denegrader in forum General Help
    Last Post: 05-02-2011, 10:26 AM
  3. WEC live tonight aug 18, versus or versus HD
    By ibanez7 in forum Almost Anything Goes
    Last Post: 08-18-2010, 01:40 PM
  4. Question: a4 versus m6
    By niterunnr in forum Camaro / SS
    Last Post: 12-14-2009, 03:24 PM
  5. Electric Versus LT1
    By Chad97z in forum LT1
    Last Post: 08-11-2007, 02:53 PM
