Thread: Clutch issues....replace?
09-10-2010, 08:49 AM #1Junior Member
- Mar 2009
- Meredith NH
Navy Blue- 2001 Camaro SS
Hey Guys,
I haven't noticed any slipping at all but after I give the car hell the clutch pedal gets real soft and doesn't engage until it is much closer to the floor than usual. Also not sure if this is related but lately it feels like the car is driving against the wind when I am maintaining speed in any gear...best description I could think off.
Thoughts?
Thanks much
Scott
01 CAMARO SS M6 NBM...Pacesetter LT, SLP Hiflows, Eibach Sportlines, Magnaflow catback, KN FIPK, SLP SFC's
99 K3500 4x4 350fi - Flowmaster 50's -295/70/17 Terragrappler on Black H2 wheels
09-10-2010, 09:27 AM #2Member
- Mar 2007
- Gainesville, VA
I don't think the second problem is related to the first. The first problem is a hydraulic issue something to do with clutch master cylinder or slave. Do a search about the drill mod and try that first. Check your fluid too make sure it's full and clean if it's really dirty remove the old fluid and put in new fluid. You could try bleeding the system as well. Those are the cheap/free things you can do to try and solve your problem. I had the same problem and ended up needing a new MC.
09-10-2010, 10:23 AM #3Member
- Sep 2010
- WI
- 2000 Trans Am
Agreed. Gm blessed us with problematic hydraulic systems. Tick makes a good master cylinder for our car that helped cure alot of peoples problems. Im running it after two stock master cylinders let me down.
09-10-2010, 10:24 AM #4Junior Member
- Mar 2009
- Meredith NH
Thanks much...I will try that.
Now I just need to figure out the other thing.
Thanks again
Scott
can I replace just the clutch on air compressor?
By perryth in forum General HelpReplies: 23Last Post: 08-09-2012, 06:50 PM -
Question: Clutch and slave cylinder replace
By YellowJacket in forum GTOReplies: 3Last Post: 07-08-2012, 03:11 PM -
time to replace Clutch...
By Corona-Extra in forum Manual TransmissionReplies: 0Last Post: 07-31-2006, 07:39 PM -
Had my rear brakes replace, got questions/issues
By Thewilldog in forum General HelpReplies: 15Last Post: 12-01-2005, 09:22 PM -
Anyone replace Clutch master or slave cylinders?
By WS6speedpaul in forum Manual TransmissionReplies: 2Last Post: 11-02-2005, 04:23 AM
