Thread: dead battery
09-09-2010, 06:04 PM #1Member
- Nov 2009
- bernaillio county
navy blue- 2002 camaro ss
dead battery
i have an 02 ss if i dont start the car at least every 5 or so days the battery goes dead. Is this common for these cars? Should i disconnect battery every time i park it? Or find out whats causing a draw on the battery with the car turned off? It has an optima red top battery in it that it came with when i bought the car about 2 years ago.
09-09-2010, 06:14 PM #2
It's easy to do a draw test... using either an amp gauge or test light, disconnect your positive battery cable. With the engine off, hook the gauge or test light between the cable and the battery post and you will see your draw. You can then pull fuses for the various vehicle systems to see the impact on your draw. If pulling a fuse for the charging system results in a dramatic drop in amps (if using a test light it will dim), then you probably have found the reason for your dead battery -- assuming it is not just an old battery that has grown weak over time. You will then need to further inspect that system to find the exact issue.
Note that aftermarket components, such as stereo equipment, alarms and such, are often the culprits.
09-09-2010, 08:03 PM #3
When you try to crank it does any of the interior lights come on? If they do and the engine still won't turn over it could be your starter. I had that happen on my Firebird a few years back and I got a new one. Also, on the battery cables take off the rubber boot and make sure the wires aren't corroded like mine were. I would spray some corrosion lubricant on the cables to make sure it doesn't happen. Hope this helps.
09-10-2010, 04:41 AM #4Electrical Engineer
- Jul 2009
- North of the Motorcity
First thing you should know is, Optima has gone to crap in the past decade or so, the quality has dropped sigificantly. I have a freind who has worked an autoparts store for along time and told he has seen the return of more Optima batteries recently than ever before. They used to be untouchable, now I would waste my money.
I would take the battery to an autoparts store and have it tested, this is pretty cheap and easy to do. B/C your battery could be one it's way out, b/c it doesn't hold a charge for long anymore.
Then I would take the suggestion from pajeff and transamgirl.
09-11-2010, 07:16 AM #5
I had an optima for my old Cobra and I was in the same boat. I drove the car once or twice a month(I had the Camaro and the Subaru at the same time). I checked for a draw and it was good, so I replaced it with a different brand and didn't have any trouble. I would first check to see if there are any draws though.
09 Vulcan 900 custom.
2007 Subaru Legacy 2.5i
1998 Z/28 Hardtop A4 | Y2K wheels | SLP Lid | Magnaflow catback |cutout | Hotchkis LCA'S/PHB | BMR TA and D/S Loop| Tuned by Frost....300rwhp/308rwtq
97 Cobra- bolt ons | full exhaust| 4.30's| suspension | SCT tune- sold!
09-11-2010, 07:21 AM #6Likes twisty roads
- May 2006
- England but from TX
Light Pewter Metallic- 2K Camaro Z28
I had Optima red top also, it took a $h!t a year later after I bought it.
09-11-2010, 12:51 PM #7Member
- Nov 2009
- bernaillio county
Thanks for all the info. The car had the optima battery in it when i bought it. Never knew they were junk. I checked for a current draw and there was none. Time for a good battery!
09-11-2010, 01:54 PM #8
I have a Red Top in my TA and maybe take it out once or twice a month and no batt issues at all. Only problem I had was with the ASP pulleys and the stock alt. weren't charging the batt. good enough but with the new 230amp replacement no more issues.
The duralast I had in my 5.0 and TA would both die on me after a couple weeks. I actually like interstate or Bosch from recent buys with my 5.0 LX and Trailblazer I have one in each and no problems at all.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
Help: Dead Battery
By 35th-ANV-SS in forum General HelpReplies: 30Last Post: 03-29-2011, 06:53 PM -
Dead Battery
By j nix in forum Stereo and ElectronicsReplies: 6Last Post: 01-15-2011, 08:02 AM -
HU install now battery dead?
By Eric1987 in forum Camaro / SSReplies: 2Last Post: 02-04-2009, 01:26 PM -
dead battery club
By issues in forum Almost Anything GoesReplies: 17Last Post: 12-22-2008, 12:54 PM -
stupid v9m battery dead
By 1MileCrash in forum Almost Anything GoesReplies: 4Last Post: 11-18-2008, 07:51 PM
