Thread: Brake issue
    Member Dewman's Avatar
    May 2008
    Midland, MI
    2000 Camaro z28
    Brake issue
    I am thinking about taking the car to the shop since i dont have much time to work on my car but i want some ideas on what to look for in case its something i can fix in a short amount of time.
    My brakes seem to be acting different almost every time i hit the pedal, sometimes they are stiff but very responsive, other times they are squishy and the last option that is the worst is the pedal feels like there is a brick under it. The car still stops then but i almost have to stand on the pedal for it to stop. The car is not throwing any ABS or CEL lights. I have checked the brake booster and it seems to be holding vac. The fluid was a tad bit low but nothing too bad so i added a little more to it. Quick glance at the pads and those seem to be decent (needs a brake job over winter but overall not that bad) Manifold is down tight and all hoses are on tight and car fires on all 8. Car does have an exhaust leak but has had that all summer and this issue has only came about within the past 2 weeks.
    Any ideas?
    2000 Z28
    Cam/Intake/Boltons
    55,000 miles
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    My first question...has the fluid ever been flushed?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I'd have to actually drive the car to be 100% sure, but some of your symptoms seem to point to a bad master cylinder.
    North Jersey
    2004 GTO M6
    I was thinking the same thing. Maybe more time has to be spent diagnosing that master? Just weird.
    May 2008
    Midland, MI
    2000 Camaro z28
    mechanic says he thinks there is a vac leak or somthing because i only am getting 4/in of vac
    Madison, WI
    2001 Silverado Z71
    how big is your cam? Big cams don't produce much vacuum
    North Jersey
    2004 GTO M6
    Kinda sounds like those writeups in GMHTP where folks have to add a "helper" booster to assist with the braking system after a cam swap.
    May 2008
    Midland, MI
    2000 Camaro z28
    The cam is not the problem, i have been driving it this way for 2 years now and never had a problem. I spent some time yesterday removing small things (valve covers, coil packs, plugs, wires, throttle body,vac hoses) and checking see if it was something else. I didnt remove my intake but i will be doing that in a few days to check that.
    Mechanic said worst case scenario is i may have burnt a valve. Not too worried though because i was on the fence about getting heads and that would be the deciding factor.
    Mods: (sorry its copy and pasted)
    !AIR
    !EGR
    SLP Lid
    UMI Lower Control Arm Relocation Brackets
    Magnaflow Catback
    FAST LSXr 102mm intake manifold
    FAST LSXr 102mm throttle body
    FAST Billet Fuel Rails
    FAST Stainless braided fuel lines with FP Gauge
    COMP Cams hi-tech pushrods
    COMP Cams dual valve springs
    COMP Cams tool steel retainers
    COMP Cams Trunion Upgraded Rockers
    COMP Cams LSR 223/232 .610/.617 112LSA
    TCI Super Streetfighter 3500 stall torque converter (not installed yet)
    TCI Shift Boss Electronic Shift kit
    Ebay Long tube headers (not installed yet)
    Base tune by Frost
  1. pvc issue... vacuum leak....tune issue?
    By okiels1 in forum General Help
    Last Post: 03-05-2016, 10:10 AM
  2. Brake Issue
    By cam02ss in forum GM Trucks
    Last Post: 07-22-2015, 09:00 AM
  3. Another signal/brake light issue
    By RamAIR23 in forum Firebird / WS6
    Last Post: 03-28-2009, 05:23 PM
  4. Brake Issue Need Help!
    By SSCO80 in forum Almost Anything Goes
    Last Post: 11-30-2008, 11:34 AM
  5. Brake bleeding issue.
    By Mr. Luos in forum General Help
    Last Post: 05-16-2007, 12:09 AM
