Results 1 to 14 of 14
    Member krese's Avatar
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    oil leaking EVERYWHERE :(
    so, i've had my ws6 for about a month and i'm wishing i never got it..... there is oil EVERYWHERE under the car... i am having a hard time finding a dry spot and now i see that the transmission gasket is leaking also..... <sigh> i don't think it is valve covers or intake but there is oil all over the opti and the CPS sensor. all over the kmember and wires up higher. all down the sides of the block on both sides.
    i'm just not experienced enough to fix this and i don't have a mechanic that i trust..... getting bummed....
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    Is motor oil or wat?
    You said is leakin from the trans is it auto?
    How many miles
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    Quote Originally Posted by 98maro View Post
    How many miles
    yeah, it's oil... the whole bottom of the motor is wet with oil and dirt in said oil.
    i think the trany is just the pan gasket, yes it is auto so that is prolly an easy fix...
    it only has 33k miles and that is prolly the issue. it sat a lot with the last owner and now i'm driving it.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    If it's all under the car (pan, frame etc) then the prime culprit is the front main seal. If it's just all over the back of the engine and tranny then it's likely the intake manifold to valley area. it's a known spot for leaking.
    FYI: Any car that has sat for long lengths of time without being run occasionally will have problems with gasket shrinkage. Nature of the beast unfortunately.
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    Quote Originally Posted by 67CamaroRSSS View Post
    yeah, i kinda knew all of this going in to it but just HOPED that it would be ok... clearly no dice....my own dumb fault. i am going to try and sell it as i have no interest in fixing it.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Quote Originally Posted by krese View Post
    If it's a low mileage car then it warrants being fixed.
    Depends on if you can do it or if you can afford it...
    Junior Member Jay789's Avatar
    Nov 2009
    Ma
    93 Trans am
    The seal on the timing cover for the water pump drive seal in timing cover might be leaking that's above the opti. I had that leak on me.
    Oct 2001
    Colorado
    95 Z28
    Really? wow... I'm sure with a little effort you could hook up with some local folks that could either help you out or point you in the right direction. Not worth selling a low mileage car because it needs a few gaskets replaced... that's just stupid (no offense).
    Feb 2008
    Brewerton, New York
    1996 Trans AM WS6
    Quote Originally Posted by 5.0THIS View Post
    as stated i don't have the money, time or friends that can help. i basically blew what money i could spend on a car with low mileage because i thought it would be safer than buying a car with 100k+ on the clock for the same price. that was the stupid part. i don't enjoy working on cars past doing maintenance items such as brakes/oil changes or car stereo stuff. i just don't. if you want to call me stupid for buying it or wanting to get rid of it that is fine, i guess i deserve it cause i feel stupid about the whole thing.
    Junior Member DannyK's Avatar
    New York
    1997 Camaro z28 Bad Kitty
    Only 33 k ? ... . ... maybe 133k .....so...first ,wash the engine and chassis and drive few miles, then check on the lift in some workshop, from where you have these leaks, it might not be a big problem and big money ... do not sell the car because of the seals or gasket leaks................. now , smile and repair this car.....
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Here is a thought:
    1-Spray some Simple Green on the engine and surrounding areas
    2-Hose off areas
    3-Let dry
    4-Check with engine running to see where and how bad the actual leak is. You don't wanna sell the car if you have, say, a broken oil pressure sender.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    lol Like I said on the other forum, how much you want for it?
    Oct 2001
    Colorado
    95 Z28
    Well, I guess if you're willing to give up that easy, just sell it to someone that will fix it up. What will really piss you off is if you sell it to someone with some mechanical ability that spends a couple hundred bucks and a weekend's time to make it a perfect 33K mile car. And you'll no doubt lose money on this deal if you sell it now.
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    i dont blame you for just getting angry at a almost brand new car leaking.
    but it is worth just giving it a quick bath and trying to figure out EXACTLY what is leaking. perfect example. my dads GTO started just pooring oil on the driveway about a week ago. and he was so frustrated he just wanted to sell it. but i convinced him to let me take a quick looky. i lifted it up washed it off ran it and let it cool for a few hours....guess what it ended up being. the oil filter. he hit a dip in the road that had a high spot! nicked the filter just enough to give some space between the block and O-ring...new filter on and good as new! it may not be that simple on your but atleast give it a chance if you really enjoy the car.
  1. still leaking...?!?!
    By sutie in forum General Help
    Last Post: 02-02-2021, 11:59 AM
  2. Leaking!!!!!!!
    By zeetwentyeight in forum General Help
    Last Post: 06-22-2010, 06:28 PM
  3. Help: A/C Leaking
    By 2K2SLPSS in forum General Help
    Last Post: 08-16-2009, 09:42 AM
  4. Something leaking?
    By 1986camarojoe in forum General Help
    Last Post: 10-11-2007, 11:05 PM
  5. A4 Leaking Can you help me out?
    By LETHALxLS1 in forum Automatic Transmission
    Last Post: 05-27-2007, 04:22 PM
