Thread: Engine Tune
09-06-2010, 09:35 AM #1おれわCamaroがいじん!
- Apr 2007
- Washington D.C.
Black- 1998 Chevrolet Camaro SS
Engine Tune
Okay, so I have had my SS for like 3 years now and I guess the previous owner never tuned the car after he installed the Dynatech headers along with the Borla adjustable catback system. I am assuming this is why my SES light has always been coming on since then giving me a P0171 code? I check the reference of the code and it always says something about my airbank #2. I haven't had the car tuned yet. Is it necessary though? If I don't will this light just continue to come on over and over? I feel like it is making my car run a little lean though. If your car runs lean too much is that bad?
09-06-2010, 10:04 AM #2Senior Member
- Apr 2010
- Alabama
the p0171 code means you are lean in bank 1 and p0174 code is a lean in bank 2. Do you have both codes? or Just the one? For me I had a vacuum leak in the tube that goes from the EGR to the intake manifold. The light won't just go away. I am not sure if it is bad if it runs too lean for a long time but I would just fix it so you don't risk it.
09-06-2010, 10:06 AM #3おれわCamaroがいじん!
- Apr 2007
- Washington D.C.
Mostly it is just P1071, but I occasionally get the 1074 code too.
09-06-2010, 02:50 PM #4Senior Member
- Apr 2008
- Madison, WI
Running lean is bad. You should get a tune with headers, but your problem might be something else like low fuel pressure or a bad MAF sensor.
09-06-2010, 03:09 PM #5
Agree with all that has been posted. Is the MAF stock?
09-06-2010, 03:18 PM #6
It has to be pretty lean to throw the codes - first thing I would check for is a vacuum leak. Would be a good idea to get some logging on it to see what the fuel trims look like...
GM EFI Tuner
2002 Trans Am WS6 - 9.41@143mph, #3675, on pump gas and drag radials - sold
09-06-2010, 05:07 PM #7おれわCamaroがいじん!
- Apr 2007
- Washington D.C.
I don't think the fuel filter has ever been changed. The MAF is also stock.
09-06-2010, 05:12 PM #8
Certainly won't hurt anything to change the filter then. If you don't find any vacuum leaks, maybe check your fuel pressure at the rail. You should have right around 58 psi.
09-06-2010, 05:18 PM #9
MS3 LS1 tune on a 5.3L MS3 engine
By slims00ls1z28 in forum Computer & TuningReplies: 1Last Post: 01-15-2012, 06:00 AM -
blinking check engine light after tune??not cool??
By stunna p in forum Computer & TuningReplies: 9Last Post: 07-13-2010, 04:59 AM -
rebuild ls1 engine with cam, diff gears, maff tune
By rikkibobby in forum Internal EngineReplies: 3Last Post: 08-23-2009, 07:32 AM -
New Engine.. Where to go for a tune in WPB.
By white99SS in forum Western MembersReplies: 2Last Post: 11-21-2007, 05:54 AM -
Who needs a Tune / Engine Rebuild??? ...
By HUGGER ORANGE SS in forum Rocky Mountain MembersReplies: 23Last Post: 02-13-2007, 12:22 PM
