    Junior Member doublea87's Avatar
    Aug 2010
    St. Louis
    2002 Trans Am
    questions about new cam
    hey guys
    so i just bought a new cam its an Erson 238/242 .620/.620 112+4 with Patriot gold springs good to .650 lift.
    what im needing to know is about what size pushrods i may need (i wil try and measure to double check), also would flycutting be an issue with this size cam? i know some guys get away with it on the MS4? one last thing would be how high to spin the rpms to for full potentioal?
    any thoughts on how this would react with stock ported heads non milled?
    i know this may seem alot but thanks in advanced!
    Car Nut ICRAZY6's Avatar
    Feb 2006
    Lacon, Illinois
    2002 Trans Am WS6
    Usually 7.4 length pushrods will be what is required but it's best to mesure. Same goes for PTV clearence, clay it and spin the motor over that will tell you if you will need to fly cut or not.
    It's a big cam, I should start coming into power near 4k and climb till 6800-7k. I'm only guessing, but my cam in my car is a 231/237 .598/.598 110+2 and it comes alive at about 4k. And I run a SS3600 Stall.
    Ported heads will help!
    Aug 2010
    St. Louis
    2002 Trans Am
    thanks for the response
    im getting a set of ported 241 heads off a buddies motor once he decides to build a new one, which will be soon lol
    i want to get an adjustable pushrod checker, cheap and a good insuracne measure.
    when claying the pistons, how thick should i spread it on? one cyl. should be enough to measure with right?
    Jun 2009
    coon rapids, MN
    2000TA
    or use a warm tootsies roll ,leave it in the wrapper .freeze it before you measure it.
    Feb 2006
    Lacon, Illinois
    2002 Trans Am WS6
    About the size of a tootsie roll like garygnu65 said.
  1. A few questions
    By blackcar in forum External Engine
    Last Post: 01-30-2012, 11:35 AM
  2. Replies: 6
    Last Post: 12-30-2011, 11:40 AM
  3. z28 questions
    By stickinpcb in forum Internal Engine
    Last Post: 04-25-2007, 01:37 PM
  4. Questions
    By The Silver Goat in forum GTO
    Last Post: 04-22-2007, 07:26 PM
  5. Questions
    By Airguy in forum Firebird / WS6
    Last Post: 04-21-2007, 12:11 PM
