Thread: Oil in the LS6 intake?
03-08-2006, 06:41 AM #1
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
I took my new T/B off yesterday to adjust the idle screw, and noticed there was a significant amount of oil film on the inside of the intake, and there was some on the rear of the throttle blade. Is it supposed to be like that? It does consume about a quart a month.
Heads 'n Cammed, Moser 12, 3.73's, Weight Reduction, 13" Brembo Kit
BMR track suspension, full exhaust, the works...
412whp/394wtq 1/4 mile slip coming soon!
Gone: '01 Laser Red Cobra 3.73's/Full Bolt-ons
03-08-2006, 09:18 AM #2
- Northern Virginia
BLACK- 2000 Camaro SS
Sounds like it's coming from the crappy PCV valve. Do a search. You should find several references to modifications to reduce the amount of oil that it allows to pass thru into your intake.
03-08-2006, 09:32 AM #3
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
If you find a link post it.
03-08-2006, 10:22 AM #4
You need a catch can....it'll catch and hold any oil your pcv sucks up and prevent it from going into your intake. I bought one from amw...works great. Here's a link
http://www.accmachtech.com/pcvcatchcans.htm
You can also make one because the amw one's are like $160Last edited by SeVeReDiStOrTiOn; 03-08-2006 at 10:24 AM.
03-08-2006, 10:28 AM #5
- Dec 2005
Pewter- '99 Z28 M6
BBK SSI Intake, vs Holley Intake, vs LS6 intake, vs PP 96mm
By Lunatikgixxer in forum External EngineReplies: 26Last Post: 02-28-2017, 10:39 AM -
Question: HOW TO: Swap stock intake with LS6 intake
By thechad125 in forum General HelpReplies: 18Last Post: 02-26-2013, 03:17 AM -
LS6 intake manifold and 227 Intake runners
By IT_SS in forum Internal EngineReplies: 4Last Post: 07-07-2009, 02:11 PM -
Single Plane Intake VS Stock PP Intake
By xzaero0 in forum Forced InductionReplies: 1Last Post: 11-27-2007, 07:00 PM -
Difference in Stock Ram Air intake and other aftermarket intake
By WS6-cobra killer in forum Firebird / WS6Replies: 5Last Post: 01-15-2007, 06:47 AM
