Results 1 to 13 of 13
Thread: New axle shafts
08-28-2010, 05:42 PM #1
New axle shafts
Hello,
Need to replace at least one of the axles on my wifes 2000 Z28. Everywhere I look on line I see W/O traction control. Are they the same axles and the TC must be switched over? If so how is it connected, bolted or pressed on? How hard is it to switch? Also where are some good places to find the axles I need?
Ken in Orlando Fl
2000 Z28 stock
2004 F-150
1973 Javelin
08-28-2010, 05:47 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I think the reluctor needs to be pressed off the old axle shaft and onto the new one.
08-28-2010, 06:01 PM #3
Pic in this post/thread of pressing the reluctor ring off an axle: http://www.ls1.com/forums/showpost.p...9&postcount=23
08-28-2010, 06:08 PM #4
Thanks that pic helped alot. So the axles w/o traction control are the same axle just need to add the TC ring?!
Ken
08-28-2010, 09:15 PM #5
I need to get a shop press... I found a cheapo w/ a hand pump on eBay for like 200 +150 for shipping. if Jeff hadn't already said he had a lift in his garage I would completely think that all his pics from his rear end install thread were takin inside of a shop lol. I'm jealous!!
08-28-2010, 10:43 PM #6
is a 12 ton shop press strong enough for pressing parts on and off the axles?
08-29-2010, 04:19 AM #7
08-29-2010, 08:13 AM #8
the one on their site for 209 is the 30 ton. I'm going to order one next week. now that will be one less thing I'll need to go to a shop for lol
08-29-2010, 04:14 PM #9Member
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
a 3 channel(ABS) axle is different than a 4 channel(ABS & TC/ASR) axle,the reluctor ring from a 4 channel axle cannot be pressed onto a 3 channel axle as it has no machined diameter to accept the ring.
08-29-2010, 06:38 PM #10
Damn well that pic came in handy huh!? ^^
08-30-2010, 08:34 AM #11
09-03-2010, 03:25 PM #12
Thank you so much. I would have hated to order one and take the other out before seeing the difference. Now the question is can I purchase the 4 channel axle and how do I ask for it so I get the right one sold to me?
Thanks,
Ken In Fl
09-05-2010, 06:34 AM #13
Can't send you a PM yet- get more posts!
I have a set of used ones from mine that I'll part with.
SLP axle back VS Borla axle back
By DVrec21 in forum External EngineReplies: 13Last Post: 01-05-2011, 03:45 AM -
Drive-Shafts..Anyone else swapped to 1 piece
By LS2Tuner in forum GTOReplies: 47Last Post: 06-17-2007, 01:45 PM -
dennys drive shafts
By jasonisdn in forum LT1Replies: 0Last Post: 04-17-2007, 04:43 PM -
how to prevent broken tranny shafts?
By silverz28camaro in forum Automatic TransmissionReplies: 0Last Post: 12-19-2006, 09:39 AM -
Carbon Fiber Drive Shafts
By 7camaro7 in forum Automatic TransmissionReplies: 3Last Post: 10-29-2005, 11:31 AM
