Thread: Need Brake lines
08-26-2010, 06:57 PM #1
Need Brake lines
Have a 98 camaro getting rid of ABS so I need the line from a non ABS car that joins the two lines in the rear into the one line that I can run into a proportioning valve. Anyone know where I can get this line or another way to run them? Went to a dealership and the lines were discontinued.
08-27-2010, 03:57 PM #2
I would contact one of the brake line companies.
08-28-2010, 09:39 AM #3Member
- Cedars, Pa
White- '02 Camaro SS
You can get tubing and fittings to fabricate your own. Use the existing tube as a template to lay out your bends. When you come up to the connection for the ABS just run it up to the proportioning valve.
09-01-2010, 05:18 PM #4
hey thanks guys I think I solved the problem. I got a hose with a block on the end of it for two lines to feed into(making two into one line) but the fittings on the ends are diff so I have to have this shop put the correct flares and fittings on the lines.
Help: new steel brake lines
By nathanWS6 in forum Suspension and HandlingReplies: 0Last Post: 08-03-2012, 12:54 PM -
Brake lines
By CHRISR96TA in forum Parts Wanted / TradeReplies: 0Last Post: 06-15-2009, 07:50 PM -
What to do about brake lines?
By patriot1136 in forum General HelpReplies: 6Last Post: 10-25-2008, 11:35 AM -
Brake lines
By Sarge in forum GTOReplies: 9Last Post: 07-24-2008, 08:59 PM -
98+ ls1 brake lines
By icemanfour662005 in forum Parts For Sale / TradeReplies: 2Last Post: 05-24-2006, 07:38 PM
