08-26-2010, 08:12 AM #1Junior Member
- Aug 2010
- San Antonio TX
- 2000 Z28
Instrument Panel Not Working Right
I have a 2000 Z28 Sometimes when i drive all my lights on the instrument panel turn on Service engine, Brake,ABS INOP, ASR off etc... They all turn on and my my Thermostat and gas and RPM gauges stop working...
08-26-2010, 04:42 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Sounds like a BCM issue if all your gauges are going wacky. If you can get to AutoZone or have a code scanner, you should be able to find out what is wrong with your ride. Keep us posted.
08-27-2010, 07:22 AM #3Junior Member
- Aug 2010
- San Antonio TX
- 2000 Z28
I just had it done and they told me all that was showing was Low Bank 2, O2 Sensor... That wouldnt be the reason the instrument panel would go crazy.. Would it??
08-27-2010, 03:56 PM #4
One of the more important factors in the electrical, BCM etc. is voltage and grounds. Step 1 take off the battery terminals, clean and tighten. Clean and tighten the ground on the fender, and make sure the ground wires at the back of the engine on the heads are tight.
Instrument panel bulbs
By cruzincamaro in forum Stereo and ElectronicsReplies: 2Last Post: 07-15-2012, 11:09 PM -
Question: Im looking for this instrument panel please help
By flyinpastu in forum Appearance SectionReplies: 3Last Post: 06-13-2012, 04:08 PM -
Corvette Gauge Clusters - Instrument Panel Dilemma
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 02-01-2010, 09:10 PM -
Instrument panel going crazy!
By BLACK02WS6 in forum Stereo and ElectronicsReplies: 4Last Post: 08-19-2007, 08:30 AM -
'99 Camero LS1 instrument panel help
By Roseracing in forum General HelpReplies: 3Last Post: 05-17-2006, 08:46 AM
