Results 1 to 1 of 1
08-26-2010, 02:50 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
October 2010 Chevy High Performance Parts - Set Al
October 2010 Chevy High Performance Parts - Set Alignment - CHP Parts
Comp Cams makes achieving perfect lobe-to-lifter alignment easy with their center marking tool, which reduces the possibility of failure when installing a flat-tappet camshaft.Comp Cams makes achieving perfect lobe-to-lifter alignment easy with their center marking tool, which reduces the possibility of failure when installing a flat-tappet camshaft. The tool set fits nearly all GM lifter bore diameters and with lightweight, precision CNC-machined aluminum construction, will not harm the cam. A common 1/4-20 threaded fit on top of the tool allows bolts to be screwed in place for easy removal out of deep lifter bores.
Photo Gallery: October 2010 Chevy High Performance Parts - Chevy High Performance Magazine
October 2010 Chevy High Performance Parts - Set Alignment - CHP Parts | Digg It | Add to del.icio.us
More...
October 2012 Chevy High Performance Parts
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-10-2012, 12:50 PM -
October 2011 Chevy High Performance Parts - CHP Parts
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-17-2011, 05:30 PM -
October 2010 Chevy High Performance Engine Guide -
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-01-2010, 02:50 AM -
October 2010 Chevy High Performance Q&A
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-31-2010, 02:30 AM -
October 2010 Chevy High Performance Letters & News
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 08-26-2010, 03:00 PM
