Thread: Tranny Blowout
08-25-2010, 05:16 AM #1
Tranny Blowout
Just blew my stock tranny in my '00 Trans Am. Lookin to upgrade that will hold the abuse she goes thru. Anyone have any suggestions on the next tranny I should buy?
08-25-2010, 06:32 AM #2
Preformabuilt. Thier a sponsor here. http://www.performabuilt.com/ go with a level 2 and it should be good for mild slightly wild apps. Get a stall and trans cooler as well.
08-25-2010, 03:46 PM #3
Thanks man. I got it to the shop and from all I know now is that I broke the transmission extension housing in 2 pieces. Tmr I will find out if it did anymore damage but this winter I will be upgrading the transmission.
08-25-2010, 03:51 PM #4
- Feb 2007
- San Diego, CA
A4 or M6?
Regardless of type it's probably the torque arm that broke the tranny tail shaft (or extension). I've seen it happen before. You might want to look into a relocation bracket or a short adjustable TA. The adjustable type allows you to set pinion angle. See my sig for what I use.
Edit: Just noticed this is the automatic tranny section so you have an A4...Last edited by 67CamaroRSSS; 08-25-2010 at 03:52 PM. Reason: DO'H!
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
08-25-2010, 04:25 PM #5
08-25-2010, 04:31 PM #6
Another Blowout
By Badass WS6 in forum Almost Anything GoesReplies: 24Last Post: 10-15-2013, 01:55 PM -
Does this look like a normal blowout?
By Blue99ls1 in forum Wheels and TiresReplies: 11Last Post: 09-20-2010, 07:22 PM -
Another Fred Beans Blowout!!!
By 877fullpower in forum Camaro / SSReplies: 1Last Post: 02-12-2008, 08:40 AM -
I NEED HELP QUICK PLEASE! Just had a blowout.
By nitrox28 in forum Almost Anything GoesReplies: 1Last Post: 06-22-2006, 08:28 PM -
Windows XP PRO OS Blowout
By Aerialist in forum Almost Anything GoesReplies: 6Last Post: 05-19-2006, 09:58 AM
