    Junior Member WonFastWS6's Avatar
    May 2008
    Kimberley ID
    02 WS6
    My winter project
    Well here it is 6.0 ly6 iron block with l92's and vvt it came out of a 07 2500 pickup HD
    vvt front cover
    Plans for the build
    Milling the heads taking 30 off to help with compression stock 9.5 to 1
    PAC valve springs
    custom cam shaft
    complete ls3 intake
    comp pushrods
    Fast throttle body
    SLP throttle cable bracket
    To delete vvt ill need the ls2 cover with sensor, cam gear with bolt and ls2 black chain tension and ls style timing chain
    Wire harness needed for the swap
    injector adapters, knock sensors ext, MAP sensor adapter
    I also need to remove the crank and change the reluctor wheel back to ls1 style 24x/1x
    Ill keep this thread updated as much as possible and will be taking pictures of the entire swap wish me luck and any suggestion are welcome
    May 2008
    Kimberley ID
    02 WS6
    Tore the heads off to day found something interesting, valve relief in the pistons. I had herd the exhaust had them but not the intake I could have that backwards. I had also herd they where flat top pistons which isn't the case.
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    if you dont mind me asking, how much did that bad boy cost you?
    i have been looking for a 6.0 block and cant find one for even a reasonable price.
    May 2008
    Kimberley ID
    02 WS6
    I paid 400 for mine but a good friend of mine works for a GM dealership
  1. What is your winter Corvette project?
    By BlownC5 in forum Corvette
    Last Post: 06-11-2012, 11:27 AM
  2. New winter project
    Last Post: 11-07-2011, 03:21 PM
  3. Winter project/questions
    By RedHot99T/A in forum Firebird / WS6
    Last Post: 01-23-2011, 11:17 AM
  4. started the winter project (pics)
    By krese in forum LT1
    Last Post: 11-27-2010, 09:08 PM
  5. Perfect Winter Project (T-top conversion)
    By dudericer in forum Parts For Sale / Trade
    Last Post: 01-11-2006, 10:46 PM
