08-22-2010, 03:37 PM #1
Auburn performance differential 3.25+
I just bought a WS6 T/A and I am hearing a whining in the rear. With those gears should the whining be normal? Just want to avoid being stranded on the road.
Sent from my Nexus One using Tapatalk
08-22-2010, 03:47 PM #2
I gave my mechanic the paper so he could research. I may be off on the gear its 3.23 or 3.25
08-22-2010, 04:10 PM #3
Could be the result of a few things. Improper backlash set-up, loose pinion due to improper set-up, wore out ring and pinion.
First suggestion would be to maybe make sure you have the correct gear oil in there. Not sure how you would know this unless you drained the gear oil and filled it with new. From what I found online about Auburn diffs, all Auburn Gear differentials require a high quality non-synthetic 80W90 GL-5 gear oil. Treat the oil with Auburn Gear, GM, or Ford additive. 3 ounces of additive per 1 quart of oil.
You don't need to worry until you hear a clicking or clunking noise usually
I'm sure others will chime in.
08-22-2010, 04:18 PM #4
Awesome, thanks a lot. I love these cars but I'm an IT nerd my under the hood experience is novice at best.
G8 Power to the Ground with Performance Differential
By Ed Blown Vert in forum Firebird / WS6Replies: 1Last Post: 11-10-2013, 04:18 PM -
G8 Power to the Ground with Performance Differential at SEMA
By Ed Blown Vert in forum Firebird / WS6Replies: 1Last Post: 11-08-2013, 02:24 PM -
Auburn-LSU
By Y2KPewterSS in forum Almost Anything GoesReplies: 6Last Post: 10-21-2007, 11:43 AM -
ebay auction for Auburn Differential
By JAGUAR5822 in forum Parts For Sale / TradeReplies: 0Last Post: 09-26-2006, 05:26 PM -
#6 LSU v #3 Auburn
By gwballin in forum Almost Anything GoesReplies: 41Last Post: 09-17-2006, 09:47 AM
