Results 1 to 15 of 15
Thread: pos ypipe help
08-22-2010, 11:47 AM #1
pos ypipe help
Just ordered tsp y and pacesetter lts
everything was going good till this stupid y i cant get it into the cat back piping
Try heating it up with a torch and nothing im getting very frusterated
08-22-2010, 12:19 PM #211 years of bangin gears
- Jan 2009
- North Jersey
What happened? Did the Y-pipe get bent in shipping? Pics would help.
Keep us posted.
08-22-2010, 12:42 PM #3
get your money back and go to a shop and have true duals with x or h pipe. half of the after market needs some type of modifing to fit right.
08-22-2010, 06:34 PM #4
I had to do some cutting to get it on
08-23-2010, 06:11 PM #511 years of bangin gears
- Jan 2009
- North Jersey
Cutting on the area where the Y meets the headers? Or where the catback meets the Y?
08-23-2010, 09:22 PM #6
08-24-2010, 05:27 AM #7O U 8 1 2
- Nov 1999
- over here...
cut a little off and use some clamps...
08-24-2010, 05:24 PM #811 years of bangin gears
- Jan 2009
- North Jersey
Were you able to fix the problem?
08-25-2010, 05:38 PM #9
Some what, the fitting is so tight it pushes my tailpipes up against my rear bumper.
I have an appointment on Friday to get it fitted better and welded instead of stupid clamps
08-25-2010, 06:03 PM #1011 years of bangin gears
- Jan 2009
- North Jersey
You have to push the catback forward to meet the Y or something? Or is the Y bent and when you connect the Y to the cat, the pipes hit the bumper?
08-25-2010, 06:10 PM #11
08-25-2010, 06:13 PM #1211 years of bangin gears
- Jan 2009
- North Jersey
Hell, you could bend the pipe yourself. Just go to Home Depot or Lowes and get one of those BernzOmatic handheld torches and connect the pipes and eyeball the pipes while you heat the Y. Done.
08-25-2010, 07:23 PM #13
08-26-2010, 02:06 PM #14
I had to cut about 2in off my catback pipe and reuse the factory clamp. I just butted the two pipes together and split the diff between the clamp. I cut the pipe just where the factory swedge is gone and back to original size. Worked perfect. BTW I wouldnt weld them together, you might wanna take em apart again...
08-26-2010, 07:13 PM #15
WANTED- catless ypipe 98-99
By red98ss in forum Parts Wanted / TradeReplies: 1Last Post: 01-24-2011, 02:38 AM -
By red98ss in forum Parts Wanted / TradeReplies: 0Last Post: 01-24-2011, 02:04 AM -
WTT:My Tru Dul 3''Xpip sys for your Ypipe CB sys
By Hot SS in forum Parts For Sale / TradeReplies: 8Last Post: 10-15-2008, 09:25 PM -
YPipe fell off on the 8
By jwindbigler in forum Western MembersReplies: 31Last Post: 01-17-2007, 02:03 AM -
Headers & Ypipe
By 99blueZ in forum External EngineReplies: 10Last Post: 06-08-2006, 10:29 AM
