Results 1 to 20 of 26
Thread: push button start
08-22-2010, 10:30 AM #1
push button start
[ame]http://www.youtube.com/watch?v=MedBTxqnPWU[/ame] i finally got the nerve to install push button start in my 2002 camaro ss, not to hard, even for a welder
08-22-2010, 10:37 AM #2Senior Member
- Oct 2008
- Coral Springs, Fl
Looks like you keep going on that car. Gets better everytime i see it.
So what's next?
08-22-2010, 10:44 AM #3
i want a complete 12 bolt or 9 inch, i really like to keep all chevy 12 bolt, but i need $$, then stronger drive shaft, and then a spec 3 or LS7 clutch, real baer or corvette caliper upgrade red of course, then i guess i wait till someone gives me 27k, then ill stop modding ha ha
08-22-2010, 10:55 AM #4Senior Member
- Oct 2008
- Coral Springs, Fl
Sure you heard this but with a 6 speed 9" is recommended. Tick has a special on monster clutches with their master cylinder i would definitely look into. I wish i would have known before i got my LS7 Clutch. Either way keep up the good work.
08-22-2010, 11:01 AM #5
how did you like the ls7 clutch compared to stock?
08-22-2010, 11:07 AM #6Senior Member
- Oct 2008
- Coral Springs, Fl
If i had to buy just the clutch, i would buy the LS7 clutch again, but like i said after i bought the clutch, upgraded all the hydraulics and bought their bleeder line, i should have just went with Ticks monster kit. Tranny needs to be pulled again though, not shifting right and after some troubleshooting i'm pretty sure its internal so i haven't really been able to slam gears in it.
08-22-2010, 11:10 AM #7
cool ill keep that in mind, have you got that ws6 cammed out?
08-22-2010, 11:11 AM #8
08-22-2010, 01:32 PM #9Member
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
where did you buy the hardware to do this?
08-22-2010, 01:35 PM #10
do you mean the push button start? i dont understand question,,,,,,,,,,,terry
08-22-2010, 08:03 PM #11Junior Member
- May 2010
- Bentonville, AR
red- 2002 Camaro SS LE
cool. the 2002 Camaro SS LE that i just bought has that installed. i was kinda skeptical at first, thinking maybe they bypassed something.
one question.......with this installed properly, and every thing working before hand, should it still start by turning the key, or is the push botton the only way it starts after installing it?
08-22-2010, 08:13 PM #12
Nice. I would also recommend the LS7 or Monster over the Spec.
08-23-2010, 03:14 AM #13
it works with the key and the button, both ways
08-23-2010, 04:03 AM #14Member
- Nov 2009
- North Carolina
08-23-2010, 05:22 AM #15
ebay honda button, someone put up a thread with complete install instructions, i cant remember who, im sure someone on this forum knows
08-23-2010, 05:58 AM #16Junior Member
- May 2010
- Bentonville, AR
08-23-2010, 07:09 AM #17
i cant help you there, but dont you need key for unlock steering wheel and accessors, you need to do some homework, and be cool, you can probally wire it up either way, just check it out
08-23-2010, 07:59 AM #18Junior Member
- May 2010
- Bentonville, AR
i still need the key to unlock the steering wheel and all that.
im just saying if i try to start the car with the key, it does nothing. almost like you dont have the clutch pushed in.
its not a big deal, its was just what somebody mentioned to me in passing after i had bought it. simply that some people instead of replacing a worn out ignition switch would just add the push botton start.
whichever push botton they used, fits inside the hole for the cigarette lighter hole perfectly.
does the Honda botton fit in the same hole?
08-23-2010, 10:30 AM #19
honda button fits with a little dremel action, and the guy that helped me install mine asked me how do you want it wired? with key or without, i said both ways please
08-23-2010, 10:48 AM #20Member
- Nov 2009
- North Carolina
Push Button Start Help!!!
By 99WS6MAN in forum General HelpReplies: 2Last Post: 07-30-2011, 05:46 PM -
Write up: Push Button Start
By Dr.Crash in forum Stereo and ElectronicsReplies: 1Last Post: 07-15-2009, 08:49 PM -
push button start?
By oreowizard in forum Firebird / WS6Replies: 12Last Post: 04-22-2008, 05:41 AM -
Any Push Button Start Installs??
By greatwhiteZ28 in forum Camaro / SSReplies: 34Last Post: 08-01-2007, 05:51 PM -
Push Button Start????
By QuickSilverGTO in forum GTOReplies: 1Last Post: 06-12-2006, 10:35 PM
