Results 1 to 16 of 16
Thread: idel and flooding problems
08-02-2005, 06:56 PM #1
- Central Texas
I just finshed build, engine and tranny rebuild and now the car has a little trouble idling and seems to be flooding out. I have open headers right now, still trying to work the kinks out. Any suggestions?
08-03-2005, 05:47 AM #2Chris 96 WS6Guest
Fuel pressure regulator busted? Check your pressure. If you're getting 43.5 psi with the vacuum tube still on then the FPR is broken.
08-03-2005, 09:55 AM #3DisCreteGuest
I'm no expert but... try adjusting the idel limit? Friend of mine has a 77 T-bird rough idel sounded like it was going to die all the time... he adjusted the idel limit and the car runs smoother now.
Assuming there's no problem as chris had mentioned.
08-03-2005, 02:02 PM #4
- Central Texas
Originally Posted by Chris 96 WS6
08-03-2005, 02:12 PM #5
- Central Texas
Originally Posted by DisCrete
08-03-2005, 05:30 PM #6DisCreteGuest
I figured it was carb'd which has a screw on one side.. which you can adjust the idel time up or down.
I'm not exactly sure as I only seen my friend do it on his car... and I'm sure different carbs have different setups.
if it's fuel injected.. it has to be program'd into the chip... in which case.. it's probably not the issue as I had mentioned previously.
-DisCrete
Maybe chris can give you a more definitive answer where the screw is located on the carb. again if you car is Fuel injected... then the problem is most likely not what I suggested.
My friend adjusted the idel timing screw "on his carb" was located on the driver side of the carburator. You may wanna check there.. do some searchin on the net for your car with the carb you are running... etc... all of this will help you find out where it is located.
I'm sorry I can't be much more help than that.Last edited by DisCrete; 08-03-2005 at 05:35 PM.
08-03-2005, 06:50 PM #7
- Central Texas
My fuel pressure was 35 psi with the key on. And it was 39 psi when the car was idling. As the car started to die it jumped up to 45 psi. As I feathered the gas to smooth it back out it came back down to 39 psi. Does this mean my FPR is going out or is out?
08-07-2005, 05:24 PM #8
- Central Texas
Okay I replaced the fuel pressure regulator and now the psi readings seem to be within spec. But she still seems to be flooding and hard to keep idling sometimes. Sometimes she idles smooth. I tried to take it down the road and I hard to feather the gas, also when feathering the gas it would cut out and die. Any ideas???
08-08-2005, 01:50 PM #9DisCreteGuest
feathering the gas to much... will stall the car out completely.. I've seen it done many times.. and on FI engines.
idea wise... dunno... maybe tune up???
or see if u can hook it up to a machine.. see if there is any error codes...
I know my car has a vaccuum hose not connected.. which I believe is causing my bog down problems.
08-14-2005, 06:46 AM #10
Re: idel and flooding problems
Have you had it tuned since the rebuild?? Is it a stock rebuild or did you change the heads? Cam? Headers? If you changed anything it's probably time to tune it. Hell I'd tune it anyway to take advantage of a fresh mill.
08-14-2005, 09:46 AM #11
- Central Texas
Originally Posted by Grimpala
MODS: 355 Block, Pistons, Crank, LT4 Hotcam, Comp Magnum 1.6 Rockers, Comp Lifters, Hardened Pushrods, Moroso CAI, Ported MAF, Ported TB, LT4 Knock Module, PCMforless Tunning, Long Tube Headers, Off Road Y-Pipe, 2500 Stall, Tranny Rebuilt, 9 Plate 3-4 Clutch Pack, Kevlar Band, Transgo Shift, Tranny Coller, New Radiator, Alternator, Battery, NGK Plugs, MSD Wires, New Fuel Pressure Regulator,
08-14-2005, 03:25 PM #12
So you have had it tuned since you got it rebuilt?
I'd look into the EGR, coolant temp sensor, or O2's.
08-15-2005, 03:43 AM #13
- Central Texas
08-15-2005, 04:29 AM #14
I didn't think that the coolant sensor would play in either. Until last summer when my car wouldn't idle and liked to die at the most inoportune times. The PCM reads from that sensor and if its too hot or cold or fluxuates a lot it throws of the PCM and causes weird shit to happen. I replaced my IAC, my TPS, MAP sensor, Collant temp sensor, all kinds of shit, until I broke down and took it to the mechanic. Tunred out that the wiring pig tail that plugs into the Coolant temp sensor was bad. GM had a bad run of these plugs, and a lot of the time they are the culprit. So $300 bucks later in labor and parts and shit I didn't need it was fixed good as new.
Is your car throwing any codes??
08-15-2005, 04:29 AM #15
Also, when you say PCMforLess...does that mean before or after the build. I'm assuming that you mean after the build, but I want to make certain.
08-15-2005, 01:27 PM #16
- Central Texas
Mississippi flooding
By staleycornell in forum Almost Anything GoesReplies: 18Last Post: 05-10-2011, 12:49 PM -
Flooding around town (pics)
By clint195 in forum Almost Anything GoesReplies: 9Last Post: 06-11-2010, 11:19 AM -
Anyone see the flooding in Atlanta?
By George in forum Almost Anything GoesReplies: 5Last Post: 09-22-2009, 03:58 PM -
Huge flooding in ND...
By Frosty in forum Political / Debate ForumReplies: 13Last Post: 03-29-2009, 09:01 AM -
help with flooding problem
By edlisaj in forum General HelpReplies: 4Last Post: 08-14-2007, 03:10 PM
