Results 1 to 16 of 16
    Member zeetwentyeight's Avatar
    Aug 2009
    A, A
    1998 Camaro Z28
    Block off plates
    Do i need to run block off plates on my LTs even if my AIR and EGR have been tuned out?
    If so where should i get them?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    yup..as with them open they will introduce unmetered air into the system..throwing off your o2's readings and making the pcm think there is a lean condition
    Aug 2009
    A, A
    1998 Camaro Z28
    any recommendations on where to get them?
    and isn't this for my water temp gauge and is it going to need to be replaced now?
    Member xmarkx's Avatar
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    yes you do. replace it before you install the headers because it will be much harder to replace afterwards.
    also, good info about the AIR and EGR systems!! I didn't know that.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by zeetwentyeight View Post
    Your new headers...if race style..will not come with egr/air provisions...if you do need them...I got mine from ws6store
    On the coolant sensor...yup needs to be replaced..looks like you didn't unplug it when uninstalling your manifolds.
    mods- suncoast creations hood with functional lt1 style airbox, ls6 intake, QTP longtube headers, QTP ORY, UMI SFC, Adj. LCA with relo brackets, UMI adj. panhard bar, Koni SA and strano springs,Torq Thrust M 17s 9.5 and 10.5 with nitto 555Rs, tuned by Frost
    Quote Originally Posted by Modulistic View Post
    sometimes you get owned, sometimes you own.
    megs 02sunsetorangeZ's Avatar
    Decatur Tx
    sunset orange
    2002 Camaro Z28
    Me and my brother just put lt's on my car friday and we forgot block off plates so we just made them in about 20 minutes.. They work just fine.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    If you're deleting the EGR and AIR then you should've purchased LT's without those hook ups. This eliminates the need for block off plates.
    Otherwise block off plates are fairly easy to fab up.
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    Quote Originally Posted by 67CamaroRSSS View Post
    you can also find them on eBay for cheap
    thunder racing has them too......I'm with the other guys though. If you have the ability to cut thin metal I would just trace out the flanges and cut your own. Very very simple. You can also use a 1 3/8" adjustable freeze plug to plug the egr port on the intake.
    2000 Camaro B4C
    i made mine it was so easy. just trace the air/egr provisions and then cut them out of a thin metal. Throw a little rtv on them to seal them properly and your good to go for under 15$
    2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
    Aug 2009
    A, A
    1998 Camaro Z28
    On the air and egr i want a emission inspector to look under my hood and look legal and yea i didn't get the race style
    I went to take it off before but it was leaking coolant all over my garage haha
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    put the block off plates on and then hook up the air and egr so the plates are sandwiched.. it might work and if it does no one would know by looking lol
    Aug 2009
    A, A
    1998 Camaro Z28
    Quote Originally Posted by Z28boy2000 View Post
    What metal did you use and how did you cut it?
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    When I made them for my motorcycle a few years ago I went to Home Depot and picked up a some aluminium stock (about 1/8" thick) and used a Dremel with a cut off wheel to make them. Very easy to do. Literally took about a half hour to make the plates- longest part was polishing them. Just use the gaskets off the EGR and AIR connections on your new plates.
    Now, if you're trying to get past inspection, you could do the sandwich method and leave everything installed, just blocking off the pipes. Keep in mind that you'll need to have the PCM tuned to cut out the codes it'll throw when you block off the EGR and AIR.
    Aug 2009
    A, A
    1998 Camaro Z28
    Egr is deleted but im waiting for my header swap and ory to tune out air
    Member JRENIGAR's Avatar
    Oct 2009
    arkansas
    99 camaro
    I broke mine installing the headers and it made the car run funny and die at idle sometimes, but its just as easy to replace with headers as it is with manifolds on. About $15 at parts store and 5 min time. Easy...
  1. Block off Plates
    By OnEbAdReDSS in forum External Engine
    Last Post: 03-02-2008, 05:47 PM
  2. Block off Plates...
    Last Post: 03-01-2008, 10:41 AM
  3. EGR/AIR Block-Off Plates
    By CWW17 in forum General Help
    Last Post: 06-01-2007, 09:57 AM
  4. WTB: EGR Block off Plates for LT1
    By BlackLT1Z28 in forum Parts Wanted / Trade
    Last Post: 10-30-2006, 07:42 AM
  5. Where can I get block off plates for EGR and AIR?
    By danman in forum External Engine
    Last Post: 10-16-2006, 06:23 AM
