    Member ls1wallen's Avatar
    Jul 2009
    Saint Peters, MO
    2001 Formula
    trouble starting
    When my car sits for long time it has trouble starting. on the second try it starts right up. when i drive it around. shut it off and try to restart it right away it starts right up. I have replaced the battery since it was 5 years old. i was thinking maybe alentator?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    As in the car cranking but no fire? Or turning the key and nothing at all?
    Indianapolis
    2000 WS6 6spd Hooker LT
    No. I'm thinking fuel pump. When it sits for a long time (over 2 weeks), the fuel system may lose its' prime, requiring more than one attempt at a start. Fits perfectly with your description, that it fires fine later.
    What do you mean by "my car sits for a long time"?
    Jul 2009
    Saint Peters, MO
    2001 Formula
    it cranks over but no fire. it can be as little as just a couple hours of sitting. I thought it was the battery at first becouse of the age and when i took it to autozone they said it was dead.
    North Jersey
    2004 GTO M6
    Sounds like either you have a clogged fuel filter or the pump is going out. How many miles?
    Jul 2009
    Saint Peters, MO
    2001 Formula
    Almost 120k changed the fuel filter around 1k miles ago maybe less.
    Indianapolis
    Quote Originally Posted by ls1wallen View Post
    But if it was your battery, it would not do the "crank over but no fire" thing.
    Leaning towards the fuel pump as well. Any way you can get a pressure checker? Should be 58+ psi, right away, with the Key On Engine Off. It will do a 2 second prime, the pressure should be there on the first prime, or the second prime at the most.
    Jul 2009
    Saint Peters, MO
    2001 Formula
    I had a gand am that had trouble like this and it was just a weak battery. That's why I thought it was just that. Fuel pump is the last thing I wanted to hear.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    sounds like a fuel pump to me also.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    this^
    Jul 2009
    Saint Peters, MO
    2001 Formula
    I think it might have been some bad gas. I filled it up at a different station and got a new fuel filter. starts fine now.
    2001 Formula ported and polished throttle body, Lid, Longtube headers, texas speed true dual, cam is the texas speed 228r 228/228 588. lift 112 lsa, tuned by Frost
    Indianapolis
    ^^^you can always hope it was that simple. Probably not, but hope so for you!
  1. starting trouble...
    By blackz28x2000 in forum General Help
    Last Post: 10-08-2010, 06:09 AM
  2. Help: Trouble with starting
    By ajs1978 in forum GM Trucks
    Last Post: 07-30-2008, 07:25 AM
  3. Help: trouble starting
    By gthb in forum V6
    Last Post: 03-15-2008, 06:14 PM
  4. trouble starting
    By garryr in forum General Help
    Last Post: 05-17-2006, 09:32 AM
